03-23-2014, 12:06 PM | #1 |
Quarry Creeper Join Date: Dec 2009 Location: San Jose
| Currie axles...need help please folks
Howdy, I decided to build my currie axles this weekend and ran into two issues that I need some help on please. 1. I am not sure where to line the chubs up on my front axle, the stock setup seems to be clocked a little forward, the chub seems to sit turned just a bit forward. Is this the same for the vanquish scale chubs and knuckles? 2. When building the front I didn't understand why I needed to put the truss on first before the pumpkin cover. So, I placed it on, saw how it went together but didn't tighten it down to put the 4 grub screws in with the truss on. Did I mess things up by doing this? Does anyone know if this is a huge deal? 3. This is a huge bummer, after putting it all together I felt binding when turning the front axle. I took it apart and noticed the longer vvd, the 5mm I just purchased and installed was bent?!?!? It has a good bend in it and I am assuming this was causing the binding. Could the truss not being in place have caused this? I really doubt it, but it did cross my mind. Or, is it just my bad luck and I received a bent vvd from the factory? Any help is really appreciated guys. Mostly, I need to know where the chubs have to sit. Steve from vanquish already addressed my issue with the bent vvd and will help me sort it out on Monday. I am anxious to find out where the chubs sit with scale knuckles on Currie axles though, please. Thanks people! |
03-23-2014, 01:27 PM | #2 |
Pebble Pounder Join Date: Aug 2011 Location: Norway
| Re: Currie axles...need help please folks
Hi I got the Currie axles with the New scale c-hubs and knuckles on my Dmg poison spyder Wraith. The only real problem I had mounting the axles was the biggest bearing on the knuckles. It was hard got get in place, I had to really force them in place. And I tought that I had done something wrong, because it was hard to turn the axles around. but when I greased them up it was fine. I clocked the C-hubs in the center position. |
03-23-2014, 09:58 PM | #3 |
Thanks for the reply, I noticed the same for my knuckles, the clearance for the inner bearings is a bit tight. When you say the center, do you mean the screw holing your chins has a gps on both sides? Or is it close to one of the sides all the way, without any gap?
03-24-2014, 07:59 PM | #4 |
Newbie Join Date: Feb 2011 Location: Wichita
When I was rebuilding mine I wasn't paying close attention to which screws I was using where (the instructions note the different lengths and their locations) and started to screw down a longer screw than spec'ed. Needless to say the screw bound up on the shaft... I took it out and compared on the bench... The one I was trying was 2mm longer then the one on the bench. Check the shaft for nicks or scuffs? You never know.
Currie axles...need help please folks - Similar Threads | ||||
few questions on VP Currie axles | m1009cucv | Axial SCX-10 | 5 | 01-10-2014 02:34 PM |
VP Currie axles or GCM Metalhead axles for scx10 | Swamp Dowg | Axial SCX-10 | 8 | 03-31-2013 11:03 AM |
New Vaquish Axles - Thank you Currie | bigstu | General Scale Talk | 60 | 12-11-2012 06:04 AM |
