Thread: May have killed my MMP
Old 03-23-2014, 09:26 PM   #1
Default May have killed my MMP
So I've had my mmp for almost a week now and love it. Took it out today and sure enough I jump a little spot on the trail into what I thought was a puddle of water. Walk over to it and find it upside down and floating. It ran just fine after i got it out but if I got more than 10ft away from me with it the receiver wouldn't pic up my radio anymore. Only other problem I've noticed is that the on off switch doesn't work on the esc anymore. It's just always on. I've pulled it all down and cleaned it with contact cleaner. Wondering if y'all think it'll be ok or if I've completely destroyed it in the long run.
JDIRCC is offline   Reply With Quote
Old 03-23-2014, 10:38 PM   #2
Default Re: May have killed my MMP
Prolly ok if the magic smoke did not escape, just let it sit for several days before you put power to it so it is fully dry. Switch would be easy to soldier a new one on.
Nissan231 is offline   Reply With Quote
Old 03-23-2014, 10:40 PM   #3
i did something similar last summer and now my MMP skips a beat while driving. Jerks as if it were a short or such?
still does it to this day.
SwampDawg is offline   Reply With Quote
Old 03-24-2014, 07:52 AM   #4
Lol yeah don't think i lost the magic smoke but i did do another rookie mistake and not cut it off immediately. i kept driving it back to the house to see if there were issues but the only one i noticed was the radio/receiver issue. but she i got it inside immediately tore it apart and cleaned and dried it all. so maybe it'll survive. casuse i sure would hate to have to spend another 130 bucks
Old 03-24-2014, 11:51 AM   #5
The switches on the mmp along with other castle esc's are known to quot working...may be betrer off ditching the switch...I usually do with all my castle esc's. I Just plug, and unplug my batteries for power..
mjc597 is offline   Reply With Quote
Old 03-24-2014, 03:23 PM   #6
yup I cut all my esc switches off solder them together then plasti dip them. haven't had any issues yet even with my MMP
Boneshaker is offline   Reply With Quote
Old 03-24-2014, 03:53 PM   #7
Most would cut and splice the switch wires together, due to the fact that it could be a POF (point of failure) and eliminate it! Hope your receiver is still good.
TheAxialNut is offline   Reply With Quote
Old 03-24-2014, 03:57 PM   #8
If it ever happens again or to anyone else, quickly unplug your battery, run inside and put all of the electronics in a bowl full of dry rice (cover the entire piece). The rice will pull the moisture away from the board. I've done it once with a servo/receiver, worked ok after they sat in rice for 2 days.
chicklet is offline   Reply With Quote
Old 03-24-2014, 07:09 PM   #9
I cut the switch off my MMP and it didn't work any more. Guy from Castle said it probably locked itself in off even though the circuit was complete.
Sent it back to KS and they put a switch on it. $75 OOW repair, I think I'll leave it on now.
drywallguy is offline   Reply With Quote
Old 03-24-2014, 07:46 PM   #10
yeah igot it all back together today and tried it everything works fine except the receiver. i have a new one but i can't get it to bind for some reason. i go through the process and it acts as if its binder but nothing works. esc sits and says theres no transmitter. i can't figure that out but i contacted the company i got the receiver from and am hoping its just faulty. but the mmp lives on lol works flawlessly. the switch even started working again lol.
Old 03-25-2014, 06:01 AM   #11
A waste of some damn good rice.
pstar26 is offline   Reply With Quote
May have killed my MMP - Similar Threads
CC mmp vs mmp sct edition? mudd_slinger Electronics 5 06-05-2013 01:18 PM
I killed it.... Mudfrog Axial AX10 2nd-gen 6 04-05-2013 01:09 PM
somebody killed bigfoot..... ScaleReady Chit Chat 11 08-30-2012 10:34 AM
killed 3 servos....now what? GSRswapandslow Electronics 19 05-12-2009 08:44 PM
Help!Help! I think I killed it SouthernHighLife4x4 General Crawlers 11 06-04-2006 09:48 PM
