04-16-2014, 02:45 PM | #21 |
Pebble Pounder Join Date: Apr 2014 Location: Trinidad
| Re: Wraith gear set up problems! Lost in the aybss
I'm new to RC as well and I also just bought a Wraith. I am looking to modify mines to increase reliability on the stock motor. From my research, an excellent starting point would be an 87/18 (spur/pinion) ratio setup. Some quick maths on gear ratios: Stock 80/20 = 4.0 ratio Suggested 87/18 = 4.8 ratio For crawling, choose a higher ratio, e.g. 87/16 = 5.4 I personally really like the stock 4.0 ratio, I like the speed and it off roads reasonable enough for me. The problem is the stock 20T motor won't last long. I bought an 87T spur and two pinions (18T and 16T) to experiment with. Of course, higher ratios = lower top speed = more low end torque. Research setting gear mesh! There are videos on youtube and many forums on it. This is important for long term gear reliability and strength. Regarding gears, pitch basically refers to the size of the gear teeth. Lower the number, larger the teeth. Larger teeth = stronger gear (but nosier). Make sure you match this! The stock 48 pitch could work, just get the mesh correct.. GET A BEC! It will increase reliability also.. Take a watch, easy stuff! https://www.youtube.com/watch?v=zdUh..._Dfiag&index=6 Last edited by 3stage; 04-16-2014 at 02:49 PM. |
04-16-2014, 03:03 PM | #22 | |
Pebble Pounder Join Date: Sep 2013 Location: Fall River
[QUOTE=3stage;4747671] Quote:
Are you high lmao , first of all it's a 17t and it's not 32p lol Sent from my iPhone using Tapatalk | |
04-16-2014, 03:07 PM | #23 |
This is my spare 17tpinion / Robinson racing machined spur on the side of a 32p 15t pinion Sent from my iPhone using Tapatalk |
04-16-2014, 03:28 PM | #24 |
One of the links you posted was for a 16t 32p pinion, the other 2 links were for 48p gearing...
04-16-2014, 03:34 PM | #25 |
04-16-2014, 03:42 PM | #26 |
No prob, just clarifying |
04-16-2014, 04:11 PM | #27 | |
| Re: Wraith gear set up problems! Lost in the aybss Quote:
04-16-2014, 04:16 PM | #28 |
| Re: Wraith gear set up problems! Lost in the aybss |
04-17-2014, 01:50 AM | #29 |
Pebble Pounder Join Date: Mar 2014 Location: U4IA Oregon
I fixed my problems there were two that I found 1. I warped the spur gear trying to drill a hole in the right spot to mount it. then after that was replaced i had to get a better gear mesh. i ran my wraith for about 40 minutes today and the motor was warm but not hot. seems like I got it worked out Thanks for everyone's help! My first paint job ever! Payed $2.79 for the LED kit just had to wire them up to a 9v connector and that's it! super low budge lighting! plus for that same 2.79 i got enough to do all my cars Last edited by THX_138; 04-28-2014 at 12:07 AM. |
Wraith gear set up problems! Lost in the aybss - Similar Threads | ||||
Wraith Heavy Duty Bevel Gear Set - Underdrive REAR - ISSUE | slimfire | Axial Wraith | 11 | 01-24-2013 04:03 AM |
just bought a 1:6...lost low gear | GeoffSFAs10 | General Crawlers | 2 | 12-30-2005 11:50 AM |
