09-30-2014, 06:29 PM | #1 |
Rock Stacker Join Date: May 2014 Location: casper
| shock angle
what gets the best performance for crawling? thanks
09-30-2014, 06:48 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
| Re: shock angle
Shocks should be close to 90* perpendicular to the angle of your lower links.
09-30-2014, 07:04 PM | #3 |
| Re: shock angle
Thanks..... |
09-30-2014, 07:07 PM | #4 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
| Re: shock angle
That depends on the setup. The more angle you put on them the softer the spring will be. It's one of those things that you play with till it feels and crawls the way you like. |
09-30-2014, 07:12 PM | #5 | |
| Re: shock angle Quote:
If you put the shock 90* vertical to the ground, it will act a little stiffer. That's why I say ~90*. | |
09-30-2014, 07:13 PM | #6 | |
personally I always like a little lean to my socks. straight up and down (90* to level ground) doesnt always work best IMO. biggest thing you can do is find the proper spring rate and shock oil/ pistons, then how much travel you actually need/ use. | |
09-30-2014, 07:15 PM | #7 |
| Re: shock angle |
10-01-2014, 08:15 PM | #8 |
| Re: shock angle
I've found this to be about perfect for me. Though I'll often lay the fronts way down to increase articulation and drop for crawling and leave the rears as is for stability. I built my rig to do all well. It fee very thing decent but is lacking in high speed stability but is still pretty stable compared to some rigs |
shock angle - Similar Threads | ||||
!!!Shock Angle!!! | jeepster73 | Newbie General | 9 | 02-01-2009 04:06 AM |
shock angle | lowlyf | Axial AX-10 Scorpion | 3 | 10-19-2008 01:41 PM |
Inward shock angle | NoblesvilleKid | Newbie General | 4 | 01-02-2008 03:53 PM |
Shock angle? | ComingApart | General Crawlers | 5 | 10-19-2007 02:18 PM |
shock angle | skrewdriver | Tamiya Clod Buster | 39 | 06-30-2006 05:19 PM |
