10-04-2014, 12:23 PM | #1 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
| Dropped stance vs. Articulation
OK, I'm having a hard time deciding which way to go here. I have a DMG front shock tower, which is nice, but with the lowered stance my front suspension travel is minimal at best. It articulates alright, but straight vertical is very small before it hits in the front. I'm afraid of hitting jumps, etc, and having it bottom out all the time. I seem to be heading into a G6 direction with it, so needs to be a crawler and have some speed as well, less of a speed/basher rig at this point. So I'm thinking of going back to the stock mounts in the front. Anyone else lower it and then go back for the same reasons? Just seeing what opinions are. |
10-04-2014, 12:28 PM | #2 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Re: Dropped stance vs. Articulation
I had the exact same thing happen with my DMG front shock mounts.
10-04-2014, 12:34 PM | #3 |
| Re: Dropped stance vs. Articulation |
10-04-2014, 05:38 PM | #4 |
Rock Stacker Join Date: Oct 2014 Location: Ft Campbell
Im looking at going with the gear head shock mounts for my upcoming build you might wanna check them out.
10-04-2014, 06:29 PM | #5 |
I'd run Traxxas revs hocks set up with bottoming buffers. With 30-50 wt oil to resist bottoming. I run proline 115mm rears with 50wt oil and all around good results. For crawling and higher speed stuff. My fronts out of control because my cheap rc4wd shocks won't hold oil. Will probly do gmade boggy back 103s on the front with 20-30th oil to start. |
10-05-2014, 12:33 AM | #6 |
I went back to stock, get the travel I want, tweaked it to get the skid level. As much as I like the lowered front end, for what I wound up doing, the extra travel will be much nicer. Now I have these two big holes in my hood though...... |
10-06-2014, 05:10 PM | #7 |
Pebble Pounder Join Date: Jul 2013 Location: Candler
What was hitting on the front to limit your up and down travel? Was it the front bumper on the servo? The reason I ask is because I had the same issue with lowering mine but I slightly spaced the front bumper out and have full travel till the little bar under the headlights flexes. Not even 1/8" of interference.
10-06-2014, 07:20 PM | #8 |
It was the upper links hitting on the bottom of the electronics box crossmember. They mount a little higher with the dinky servo mount.
10-06-2014, 10:33 PM | #9 |
RCC Addict Join Date: Aug 2007 Location: Seattle
10-07-2014, 12:56 PM | #10 |
Newbie Join Date: Sep 2014 Location: Saratoga Springs
I tried proline powerstroke slash 4x4 front shocks on all four corners of my wraith and felt like it limited articulation drastically. Gonna try rear powerstrokes on all four corners now. Anyone else have this issue?
10-07-2014, 01:04 PM | #11 |
Pebble Pounder Join Date: May 2013 Location: Lees Summit
I dropped the stance on mine quite a but and I'm using the Proline ProSpec Slash Rears. It sets plenty low enough for speed but has no problems in and on the rocks. Though I'm using the DMG front shock mounts that he includes with the stiffy kit. May not be as drastic as the ones you were using. I get full articulation (though I'm not a "flex" nut). |
10-07-2014, 05:01 PM | #12 |
10-07-2014, 05:03 PM | #13 |
Yes found the same thing sold my short set and got the rear set. Much happier now! |
10-07-2014, 05:09 PM | #14 |
After installing the long Proline Power Strokes Both rigs with long ProLine Power Strokes |
10-07-2014, 06:33 PM | #15 | |
| Re: Dropped stance vs. Articulation Quote:
My shock mounts stuck through the hood, so it dropped it quite a bit. And for speed and bashing around it was great, much more stable, but with the G6 being the goal, I needed some more flex. It was OK left and right, actually, but over jumps it had very little vertical. I think I 'm happy with it now. Until next week...... | |
10-19-2014, 07:48 AM | #16 |
Newbie Join Date: Oct 2014 Location: southeast mo
Mine is lowered by lowering kit and turned shock/4link mounts upside down and run a longer hot racing shock. I just mainly crawl. Has great flex and stability. Very capable crawler. Traxxas servo is just a spare,waiting on new one Last edited by THX_138; 12-22-2015 at 09:11 AM. Reason: Merge |
10-19-2014, 08:13 AM | #17 | |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
Wes | |
10-19-2014, 10:22 AM | #18 |
10-19-2014, 10:46 AM | #19 |
Quarry Creeper Join Date: Sep 2011 Location: NW
10-19-2014, 11:20 AM | #20 |
Dropped stance vs. Articulation - Similar Threads | ||||
Stance | jayross101 | Axial Wraith | 5 | 08-27-2012 04:32 PM |
Wider Stance? | The Jackalope | Redcat Crawlers | 6 | 05-01-2011 06:07 AM |
Weird Stance | MaverickMatt | Newbie General | 9 | 12-26-2010 05:34 PM |
