10-12-2014, 11:43 PM | #1 |
Quarry Creeper Join Date: Nov 2013 Location: florence ky
| Problem!
So I was doing the battery relocation mod on my wraith and after finishing i plugged in a battery... there was a short and faint "pop" then nothing... now when I plug a battery in I get absolutely nothing from the esc.... Did I short out the esc? I never unplugged any of the connections while doing the mod... only thing I can think of is the sheet metal plate that I made to replace the battery box to mount the esc and switch to is the culprit... So what do you think? Is the esc smoked? if so is there anything i can do rather then buying a new one? |
10-13-2014, 12:00 AM | #2 |
Quarry Creeper Join Date: Aug 2013 Location: South Crawlolina
| Re: Problem!
If you or a friend has another battery, I would try that. I would take the case off the ESC to inspect the circuit board. What ESC do you have? And ALso what battery?
10-13-2014, 12:02 AM | #3 |
| Re: Problem!
I have several 2s 5000mah onyx batteries and the reveiver is a ae-2.... I have already tried eliminating the swith as well
10-13-2014, 12:19 AM | #4 |
| Re: Problem!
ok I figured it out... ended up just being a bad deans connector that is soldered to the esc.... one of the springs on the prong is missing
Problem! - Similar Threads | ||||
Problem with Tekin RS system in my LCC, will a BEC fix my problem? | rcboy514 | Electronics | 3 | 01-12-2012 05:55 PM |
Tekin Problem or Radio Problem? | Harvo | Electronics | 8 | 07-30-2010 06:02 AM |
Little bit of a problem, Possibly big problem... | C_Money | Electronics | 11 | 03-08-2010 05:49 PM |
Charger problem or power problem? | Rockfrog | Electronics | 4 | 10-09-2009 01:10 PM |
* Problem * Clicking Problem on my 1/18th | clodman | General Crawlers | 6 | 04-08-2006 08:40 AM |
