Thread: New to the Rc and forum world advice please
Old 10-29-2014, 09:01 AM   #1
Default New to the Rc and forum world advice please
Ok so i have an actual Jeep wrangler that i rock crawl with and i wanted an rc one as well since i discovered that there was such a thing. Well i finally got one and my first one is this Axail Wraith Rock racer. Within first 5 minutes of wheeling it i stripped out the stock servo... Replaced it with one that won't strip out supposably ran about $60 and is waterproof. Now after a couple of days out heeling with it i burnt up the stock motor... I am rough on all my toys. So now i am overwhelmed with the amount of info on motors gears and sorry for my ignorance but what does esc stand for?? I don't race it but i wheel it on rocks and rock piles and basically anything that looks challenging. So my questions would be what motor recommendations gearing should i get and also am i gonna need to get a different battery than the 2 cell lipo i have now??? Please dumb it down for me as much as you can i learn quick but like i said the info is overwhelming and all the cool new shiny stuff i can put on it my brain is already fried with stuff i want... So first of all what do i need to get running reliable again i don't wanna break real quick i like to replace with quality and an upgrade..
Hope this is in the right place
and thanks for the info in advance
Ghostryder675 is offline   Reply With Quote
Old 10-29-2014, 09:24 AM   #2
Default Re: New to the Rc and forum world advice please
ESC stands for electronic speed control, in a nutshell, get yourself a holmes hobbies torquemaster pro or expert 35t motor and you can use your stock ESC. Stay with your 2s lipo for now...change the pinion gear to a 14t gear if you stay with the 48p spur gear. you can swap out to a 32p spur and pinion, in which case you would want to go with 56t spur and a 10-12t pinion depending on your preference.
You may need to add in a BEC for your steering servo if its torque is over 200oz or so
I would upgrade to beeftubes and aluminum knuckles,chubs and lockouts..strc is a pretty decent brand....
steering links changed to aluminum, or stainless steel..many vendors have these...
front and rear links either aluminum or stainless steel, avoid the ones that have the pivot balls built in, use ones with replaceable ends.
get a set of MIP driveshafts and be done with that...
replace the internal trans gears with HR steel gears
convert the wheels from pin hubs to hex hubs
as you run it more you will want to do other upgrades such as going with a brushless setup and 3s lipos..universal joint axles...shocks..etc....
allanon1965 is offline   Reply With Quote
Old 10-29-2014, 09:27 AM   #3
I could offer my two pence but it said much much better in the Stickies at the top of this forum. You bought a great truck.
I run a 27 turn motor though for reference.
o0wiz0o is offline   Reply With Quote
Old 10-29-2014, 10:36 AM   #4
x2!
sic1to is offline   Reply With Quote
Old 10-29-2014, 10:57 AM   #5
hey thanks for the info i will get on that immediately!! But um..... what is a bec???
Old 10-29-2014, 11:05 AM   #6
battery eliminator circuit...
my preference/ie: Castle Creations | CC BEC and CC BEC Pro
TacoCrawler is offline   Reply With Quote
Old 10-29-2014, 11:06 AM   #7
Holmes Hobbies LLC
It is used to regulate voltage to your servo in most cases to assure max torque at all times not pulling juice from esc. I run a bec on all my rigs!
Old 10-29-2014, 11:35 AM   #8
zjguy721's Avatar
You do this long enough, you wind up being an electrical engineer ;)
I would suggest investing in a good soldering iron and learn how, you're going to need it =)
zjguy721 is offline   Reply With Quote
Old 10-29-2014, 11:36 AM   #9
Is there a write up on how to do this conversion?
LooseMoose1978 is offline   Reply With Quote
Old 10-29-2014, 11:49 AM   #10
nope, not that I have seen,
just install 12mm wraith hexes over the existing pins, easy as that. then you can run any 12mm hex wheel...the stock poison spyder wheels will need the pin hubs changed out to hex hubs from VP or other aftermarkets that will fit..
Old 10-29-2014, 12:52 PM   #11
[QUOTE=allanon1965;4931069]
Ok, thanks. I was a bit confused by the pins/setup of the poison spyder wheels.
Old 10-29-2014, 03:59 PM   #12
Sorry for asking this, since this threat isnt mine, but do we have to use a bec when we have a 2S lipo and a non digital servo our even with digital servos we have to use the bec?
PSH72 is offline   Reply With Quote
Old 10-29-2014, 04:23 PM   #13
"YES"You need a bec on everything IMO! 2s-6s don't matter its a must on most servos even stock to get the most torque plus keep from causing power loss to other components since battery is running motor,esc,lights,winch etc...some esc's come with internal bec's but don't set voltage to one or more servo's,winches,lights blah blah blah so when reading the STICKY'S(electronics,newbie,general,scx,wraith,etc ... at the top of any forum page will answer almost any question you have & SEARCH will complete any answer!
Old 10-29-2014, 05:33 PM   #14
Dont sweat it, we've all been in your shoes, utterly confused and overwhelmed by the choices in front of us. You'll get there! Next thing you know, you'll be advising one of your friends on something RC and have this moment of "Hey wait. I actually know what im talking about now!"
The advice given here so far is A+ quality, so I dont have much to add outright. As for this question:
Do you HAVE to? As in, 'will my shit break if I dont', is no. When I first got my digital servo, the BECs were out of stock everywhere within a 100 mile radius of me. I actually ran it a few times (though admitedly very carefully and gently) before I got a Castle Creations BEC like was linked above. Ive run mine off 2S LiPo from day one without issues.
Suffice to say, you dont NEED one to survive, but it certainly will help a lot. Much in the same way that you dont NEED a bulletproof vest to survive getting shot, but it sure helps alot ;)
Odinthor is offline   Reply With Quote
New to the Rc and forum world advice please - Similar Threads
New to forum and asking for first-truck advice DieCastoms Newbie General 22 04-14-2013 10:13 PM
**UK Forum Member** New Purchase! Plus some Lipo, Motor & Charger advice please? iheartoldskool Losi Micro-Rock Crawler 3 10-21-2012 01:31 PM
I'm new to the forum and to the rc crawling world jonnyp Tamiya TLT Crawlers 9 11-23-2006 07:33 AM
