11-23-2014, 04:02 PM | #1 |
Newbie Join Date: Jul 2014 Location: Murrieta
| Want to upgrade shocks
I would like more flex, I'm not sure what shocks to put on which one should I use?
11-23-2014, 04:10 PM | #2 |
| Re: Want to upgrade shocks
how much flex do you have already? too much flex is not good...rule of thumb is your flex should not be more than the height of one tire....around 4.5 to 5.5 inches usually... proline slash shocks are good choices...either 4 fronts or 4 rears...depending on on the ride height you want. |
11-23-2014, 10:13 PM | #3 |
Quarry Creeper Join Date: Nov 2013 Location: florence ky
im running 110mm rc4wd king shock with the piggy back and a droop lowering kit installed and just a few limiters
11-23-2014, 11:07 PM | #4 | |
| Re: Want to upgrade shocks Quote:
11-23-2014, 11:08 PM | #5 |
| Re: Want to upgrade shocks |
11-24-2014, 01:34 AM | #6 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
I'm running Traxxas Bigbores XXL. For the price nothing will beat these, half the price of Proline Powerstrokes, and they will be a huge upgrade to the poor stock shocks.
11-24-2014, 02:52 AM | #7 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
11-24-2014, 02:56 AM | #8 |
Newbie Join Date: Jun 2014 Location: Australia
Im running the King 110s. First run has all 4 leaking and they are way too soft. I will be picking up some Kyosho's from Super Shafty ASAP.
11-24-2014, 05:56 AM | #9 |
RCC Addict Join Date: Feb 2012 Location: UK
If you like the Traxxas shocks just get the stock Ultra shocks. Add Aluminum shock caps and they are better than the Big Bores. Despite the name 'Big Bore' the plastic the Ultra shocks hold more oil. |
11-24-2014, 08:22 AM | #10 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
| Re: Want to upgrade shocks The down side is the plastic bodies will leak. The aluminum ones won't ever leak unless you put them together wrong. I do agree the name " big bore" is misleading.
11-24-2014, 08:39 AM | #11 |
I'd have to disagree. My Slash Ultra shocks (With Alloy caps) take a massive beating at high speeds and are fine. Every stock axial shock I have owned leaked out of the box. Haha. A Traxxas shock is designed to be used in much harsher conditions than the Axial Wraith/Scx10 would be used in. They are built for bashers at the end of the day.
11-24-2014, 08:59 AM | #12 | |
11-24-2014, 09:20 AM | #13 |
Good point.
11-24-2014, 06:40 PM | #14 |
Ok so it seems like the traxxas shocks might be the way to go, what size 110mm? And what about integy how is that brand? I've always had team associated and always just used their parts or proline.
11-24-2014, 08:43 PM | #15 |
Rock Crawler Join Date: Nov 2005 Location: Fremont/Newark, California
I just put the CKRC brand on mine, swapped the springs and so far so good.
11-24-2014, 11:59 PM | #16 |
Rock Stacker Join Date: May 2014 Location: vancover island Canada
11-28-2014, 03:01 PM | #17 |
Do you know what weight oil comes in the stock wraith shocks? Sent from my iPhone using Tapatalk |
11-28-2014, 03:54 PM | #18 |
Quarry Creeper Join Date: Aug 2014 Location: San Diego
I have some chrome ones. I believe 100mm-110mm not sure. I put 30 weight in they. I read that is recommended for just cruising and some crawling. I got this used roller for $100. I put a used novak brushless setup in it. And walla. These shocks work great with 30 weight. I have also had no leakage since I bought it and cleaned them up. So I do agree aluminum bodied shocks work better than stock plastic. I have proline rears all around for my slash 2wd. ,rc4wd king shocks for my scx10 and these for my Wraith. None leak. |
11-29-2014, 04:59 PM | #19 | |
How do you like those king shocks? Sent from my iPhone using Tapatalk | |
12-01-2014, 12:33 AM | #20 |
I really like them. Super soft but 110 are a little too long. You can hear the stock driveshafts kinda grind when the scx10 is off the ground because they are too angled. But on the ground when the driveshaft are normal, they perform way better than the G6 kit shocks.
Want to upgrade shocks - Similar Threads | ||||
What shocks would work as upgrade?? | ZippoMan | G-Made Sawback | 13 | 07-08-2014 01:21 AM |
Honcho Upgrade - Links and Shocks | XS NOIZ | Axial SCX-10 | 0 | 10-09-2013 12:10 PM |
looking to upgrade shocks | m1009cucv | Tamiya XC/CC01 | 8 | 03-11-2011 06:27 PM |
looking to upgrade my ax10 shocks | penry | General Crawlers | 3 | 05-30-2009 09:43 AM |
upgrade shocks | Azcats1 | Axial AX-10 Scorpion | 7 | 08-30-2007 09:43 AM |
