Thread: Free wraith mods
Old 12-21-2014, 06:20 AM   #1
Default Free wraith mods
Just got my wraith u cash is tight anyone know of any mods for free? Or using stuff laying about?
Cheers
ts4n is offline   Reply With Quote
Old 12-21-2014, 06:32 AM   #2
Default Re: Free wraith mods
Best free mod, the search box at the top right of the page.
altd896 is offline   Reply With Quote
Old 12-21-2014, 06:40 AM   #3
The search everything answer certainly kills peoples joy of a forum. This thread should give something: cheap or free mods that work well
Odd-M is offline   Reply With Quote
Old 12-21-2014, 08:22 AM   #4
In Harley's "Poison Spider Wraith budget build" videos he did a couple of free mods, but they were more geared to after you had been running the truck for a while. Check out the series. It is full of good ideas.
And welcome to the madness...lol
Jonnie Fraz is offline   Reply With Quote
Old 12-21-2014, 10:00 AM   #5
Cage mods are probably the cheapest and easiest to do. A must mod would be moving the battery forward.
Z0MB13 is offline   Reply With Quote
Old 12-21-2014, 10:38 AM   #6
I second this!!! There are "many" free mods that can be done, and do work. Biggest one that works the best is: Run it to death and have a blast!! Wraiths are like cats, and love to play!! Enjoy, Ron
blckgnx is offline   Reply With Quote
Old 12-21-2014, 12:09 PM   #7
Theres a sticky on this also
gsrcivic is offline   Reply With Quote
Old 12-21-2014, 12:30 PM   #8
battery in the front
flip the lower shock mounts to lower a bit
also rear shock "tower" can be flipped as well
fastback mod on cage
those are just a few
EDDIE THE YETI is offline   Reply With Quote
Old 01-07-2015, 06:16 PM   #9
I just bought a wraith spawn and was looking to do some mods and saw the battery forward mod, but heard in a video that unless it's a dedicated crawler it's not the best mod to do. What are the thoughts on this.
Sent via smoke signals
Mr.E is offline   Reply With Quote
Old 01-07-2015, 06:27 PM   #10
Yup this forum thrives on posts and members.
Man it would be scarey if harley was the only one posting and we as members could on search his thread because we all know that everything wraith has been covery there.
Alot can also be learned about rc in general on rc groups and others. Airplane and heli guys know there shit.
evan03 is offline   Reply With Quote
Old 01-08-2015, 06:39 AM   #11
Its each to their own. I ran mine for ages with the Bat in the rear and it still climbs and trails well. Shifting the weight though may get you over the one obstacle in ten that it fails on. If you intend on hitting a lot of very steep angle where the truck is falling backwards then its a good idea to move it.
o0wiz0o is offline   Reply With Quote
Old 01-08-2015, 03:16 PM   #12
Mr. E, I recently got a Spawn and did the forward battery mod. It made a considerable difference in climbing. The only bad part is having to remove the body to remove the battery.
DMK855 is offline   Reply With Quote
Old 01-08-2015, 05:00 PM   #13
Thanks,i I was kind of wondering about how it does with jumps and stuff with the extra weight in front.
Old 01-08-2015, 05:39 PM   #14
It does fine
maslin is offline   Reply With Quote
Old 01-09-2015, 05:04 AM   #15
I used SCx10 shock mounts where wraith mounts are...lowered quite a bit and combined w long travel shocks it flexed like a boss...
87yota is offline   Reply With Quote
Old 01-09-2015, 06:34 AM   #16
Some folks use rare earth magnets to hold the body on and make removal easier, while others cut the hood off completely and install it back hinged with body pins and posts to hold it down.
StomperCrawler is offline   Reply With Quote
Old 01-09-2015, 11:01 AM   #17
I say battery forward for a trail rock rig.
Leave the battery in the rear for a jumper basher only rig. Or possibly central mounted for best flight characteristics
Old 01-09-2015, 10:38 PM   #18
So how do you mount the battery up front?
I started looking at mine while tearing into it some to change the battery connections and the wires off the esc go into the electonics box are tight and cant hardly move it anywhere let along mount it in the back.
squeaky3 is offline   Reply With Quote
Old 01-10-2015, 11:57 AM   #19
If you pull the radio box apart there will most likely be a bunch of wire coiled in the box. To keep everything nice and tidy. There should be enough slack to move the esc. When I initially moved my battery forward I moved the radio box to where the battery was and made it look like a tool box or cooler. Then put the esc where the radio box was.
redneckwraith is offline   Reply With Quote
Free wraith mods - Similar Threads
Free Wraith mods Geck0Jeep Axial Wraith 9 07-15-2014 11:25 AM
free mods sam.oc235 Axial SCX-10 8 01-26-2011 03:11 PM
Free mods TAT76 Losi Mini-Rock Crawler 9 10-23-2009 03:35 PM
free mods bigblazerboy HPI Wheely King 23 12-22-2007 10:02 PM
My free mods. kennebell50 HPI Wheely King 0 09-03-2007 06:33 PM
