01-18-2015, 12:31 PM | #1 |
Newbie Join Date: Oct 2014 Location: Fort Wayne
| What to do first to the Spawn???
I have a new Spawn and have already done a few mods, such as moving the battery and esc to the front and receiver to the rear. Added a set of Hot Racing links and steering linkage, and have a Castle bec ready to install. I've watched Harley's PS build and learned a ton, but I'm wondering what mods you guys consider have to be done right away?
01-18-2015, 04:38 PM | #2 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
| Re: What to do first to the Spawn???
Upgrade the stock plastic steering links, it'll be one of the best investments you can make. The stock plastic ones are flimsy and bend easily when turning. Look up Harley's guide thread here. Tons more info and advice. |
01-18-2015, 04:59 PM | #3 |
I joined the Band! Join Date: Dec 2014 Location: Earth
Sounds like you've already done all the "right away" upgrades on your Spawn.
01-18-2015, 05:15 PM | #4 | |
| Re: What to do first to the Spawn??? Quote:
Now you just drive it till you break something, or till you find an area that needs adjustment / improvement. | |
01-18-2015, 05:54 PM | #5 |
| Re: What to do first to the Spawn??? I do the same thing, just completely miss one or two key details for no reason at all. Just somehow miss them entirely.
01-18-2015, 06:35 PM | #6 |
Rock Stacker Join Date: Aug 2007 Location: Ventura, Ca.
youre linked up and have a bec, my next upgrade would be a steering servo |
01-18-2015, 07:20 PM | #7 |
Yeah, seems to be a loaded question as to what to do as each guy is different. I was just curious to hear what guys do right away out of the box with a RTR. I've heard anywhere from new servo, stage 1 kit, to shocks, etc.....
01-18-2015, 07:39 PM | #8 |
Wish I was more familiar with the Spawn edition. I know it's had upgrades such as servo and etc over the previous versions, I just don't know what all has been done and the quality of the parts used. You should run it for awhile and decide if you want more speed, stability, etc.. There's so many upgrade options to choose from. Steel trans gears, shocks, etc.. Really just depends on what all you plan to do with it. |
01-18-2015, 08:03 PM | #9 |
It has 32P gears now and the servo is supposed to be better than the original but other than that it is still the same Wraith, or so I've read. The esc is a step down from the AE2 though. The driveshafts are supposed to be stronger now too.
01-18-2015, 08:39 PM | #10 |
Newbie Join Date: Jan 2015 Location: Seaside
Get the hood pin kit and install them in the holes you use to screw the body on. Then you just have to pull out 4 clips to get the body off.
01-19-2015, 03:02 PM | #11 |
Newbie Join Date: Sep 2014 Location: Boone Co.
| Re: What to do first to the Spawn??? Good idea! I just got my Spawn body for my new build and thought about how old it's going to get taking the screws out to change a pack everytime.
01-19-2015, 03:08 PM | #12 | |
02-11-2015, 05:49 PM | #13 |
Newbie Join Date: May 2014 Location: Twin Cities
Where can I get this hood pin kit?
02-11-2015, 06:04 PM | #14 |
Blue Monkey has one for Wraith hoods. http://www.bluemonkeyrc.com/catalog/...roducts_id=292 ...and this one for the hinged hood on the Wraith. http://www.bluemonkeyrc.com/catalog/...roducts_id=291 I believe some have also used this kit from Traxxas, you would need two kits for mounting a Spawn or other full body. TowerHobbies.com | Traxxas Battery Hold-Down Plate Gray (2) Last edited by Eric0424; 02-11-2015 at 06:34 PM. |
02-12-2015, 08:20 PM | #15 |
Pebble Pounder Join Date: Apr 2013 Location: Charlotte, Mi
| Re: What to do first to the Spawn??? Last edited by Wehan; 02-12-2015 at 08:24 PM. |
02-12-2015, 09:48 PM | #16 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
Steel diff skidplates from BlueMonkeyRC. So much better than aluminum skidplates or no skidplates at all.
02-13-2015, 02:00 PM | #17 |
Rock Stacker Join Date: Mar 2012 Location: SoCal
Congrats on your new wraith! If you haven't done so already, check on those pin drive hubs. That has been a noted problem area with Axial's IFD wheels. Vanquish SLW hubs is one solution to replace stock plastic.
What to do first to the Spawn??? - Similar Threads | ||||
Axial spawn | 98sierra | Axial Wraith | 30 | 07-27-2015 06:12 PM |
Spawn! | FortCrawler | Axial Wraith | 39 | 02-04-2015 03:35 PM |
Spawn | jlsandkes | Axial Wraith | 2 | 11-17-2014 01:27 PM |
