Thread: Hot Racing Double Up Clutch over kill ?
Old 02-28-2015, 09:40 AM   #1
Default Hot Racing Double Up Clutch over kill ?
I was looking up all the slipper clutches that could be used on the wraith and with the Beefy Top shaft Traxxas Slash comes in.. well an upgrade to the Slash is a E Revo slipper.. alot bigger.
Well Hot Racing has the double up slipper.. you can now use 6 slipper pads not just 3.. or a T Maxx disk brake pad.
I like this over the RRP as you can change the spur gears.
Is this E Revo sized slipper over kill with my setup ?
HH esc and TQmaster 27t on 3s
SouthernComfort is offline   Reply With Quote
Old 02-28-2015, 09:50 AM   #2
Default Re: Hot Racing Double Up Clutch over kill ?
E Revo slipper vs Slash
Hot Racing Double Up Clutch.
Old 03-04-2015, 12:19 AM   #3
Well no one had anything to say so I went with the Slash slipper not the Revo or the Double up slipper.
Stock Slash is still alot better than the Axial unit.
Old 03-04-2015, 03:59 AM   #4
I have the Revo Slipper waiting in the wing to go on. It's a beast!
o0wiz0o is offline   Reply With Quote
Old 03-04-2015, 08:51 AM   #5
2013 2.2P Nat. Champion
SkaldidDog's Avatar
Don't waste your money. Revo unit or just buy a lockout. Slippers are useless in a Wraith.
SkaldidDog is offline   Reply With Quote
Old 03-04-2015, 08:57 AM   #6
Well I like to run one.. but the more I beef it up the tighter I can run it.
After this round of upgrades the axle shafts themselves are the weak link.
I thought about a slipper eliminator but said naw I'll keep one.
Old 03-04-2015, 09:05 AM   #7
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I like running slippers. Gives enough cush to keep my driveline a bit happier when I catch air. I like to have the shafts running from axle to tranny as the weak link. They are easy and fast to replace compared to any other parts.
JohnRobHolmes is offline   Reply With Quote
Old 03-04-2015, 09:13 AM   #8
Well I will have. Traxxas 32p plastic spur..
Beefy topshaft..
RRP trans gears stock outputs. .
Maxx drive shafts. .
Mini Loco axle bushings..
Axial HD 43/13 gears.
Stock Axial axle shafts.
Old 03-04-2015, 09:27 AM   #9
SkaldidDog's Avatar
I agree. Plastic TMaxx shafts act as my torque absorbers. I don't want any slipping while bound up crawling.
J
Old 03-04-2015, 10:52 AM   #10
Natedog's Avatar
x2, preferably lockout.
... I like to have the shafts running from axle to tranny as the weak link. They are easy and fast to replace compared to any other parts.
Plastic spurgear and driveshafts as quick, cheap and easy to replace and less rotating mass.
Beefy topshaft..
Ditch the RRP tranny gears and get a set of HR lightweight gears, much lighter and take more abuse.
Hot Racing Super Duty Light Weight Steel Gear Set SCX10
or Hot Racing standard weight tranny gearset
Hot Racing Axial SCX10 AX10 Wraith hard steel center gears set
Old 03-04-2015, 10:59 AM   #11
Exclamation Re: Hot Racing Double Up Clutch over kill ?
slipper's r 4 wimpkinds!
corefire is offline   Reply With Quote
Old 03-04-2015, 11:09 AM   #12
Suck it up!
Duuuuuuuude's Avatar
I run slippers in anything that goes fast, and lock them down/remove them on anything that goes slow. Shock load seems to do more damage than torque load.
Duuuuuuuude is offline   Reply With Quote
Old 03-04-2015, 11:54 AM   #13
SkaldidDog's Avatar
And the more hundreds of hours you spend driving various RC's the better you'll get at matching wheel speed with landing speed/angle so that landings take less of a toll. Newbs should run slippers. That last sentence provides a humorous image.
J
Old 03-04-2015, 12:04 PM   #14
Suck it up!
Slippers are better than crocs...
Old 03-04-2015, 12:26 PM   #15
SkaldidDog's Avatar
And Crocs are better than wellies.
J
Old 03-06-2015, 10:11 AM   #16
Thank God no-one mentioned Uggs.... uhm oops.
wouterb is offline   Reply With Quote
Old 03-06-2015, 10:22 AM   #17
I was just wanting to keep from killing my axle shafts.
And whats wrong with the RRP trans gears ?
Old 03-06-2015, 11:04 AM   #18
maslin is offline   Reply With Quote
Old 03-06-2015, 11:07 AM   #19
Im not getting the one piece. ..
Hot Racing Double Up Clutch over kill ? - Similar Threads
Hot Racing Links are hot mess!! Sethmetal Axial Wraith 53 04-12-2013 12:27 PM
Converting To a Robinson Racing Slipper Clutch tractionaction Axial SCX-10 0 06-15-2012 03:56 AM
Double wave Slipper Clutch Wetfoot Axial AX-10 Scorpion 10 06-24-2008 01:07 PM
