Thread: Crazy steering with XR10 knuckles
Old 03-01-2015, 05:34 PM   #1
Default Crazy steering with XR10 knuckles
Hi, I wanted to try to make one of my wraith into a somewhat better crawler, and installed XR10 VP knuckles and RC bros XR10 knuckle weights. And when I turn the wheels by hand it got crazy good steering angle. But it does not seem like the servo has equal amount of angle. I tried with a bit longer arm, but can't go too long, cus then it will hit the tierod. Any tips on how to utilize all that gained steering angle?
AngelowDoom is offline   Reply With Quote
Old 03-01-2015, 05:39 PM   #2
Default Re: Crazy steering with XR10 knuckles
some pics
Old 03-01-2015, 05:45 PM   #3
This is max steering angle when I turn the wheels by hand
This is max when I power on the servo and it does the steering.
Old 03-01-2015, 06:24 PM   #4
Did you try adjusting the steering trim on your radio?
tacocat is offline   Reply With Quote
Old 03-01-2015, 06:41 PM   #5
Adjust the travel/epa in your controller
Ren
legoman819 is offline   Reply With Quote
Old 03-02-2015, 07:59 AM   #6
Try to roll it with the wheels turned that far. The universals will bend 90* sitting still.
maslin is offline   Reply With Quote
Old 03-03-2015, 05:08 AM   #7
I thought the wraith knuckles and xr10 knuckles were the same thing?
novarider is offline   Reply With Quote
Old 03-03-2015, 06:16 AM   #8
Not the VP ones, and it is those the knuckle weights I wanted to try fits.
Old 03-03-2015, 07:53 PM   #9
You need the zero ackerman tabs. I use them on the xr10 axail knuckles I run now.
Axial Zero Ackerman Steering Plate Set (2) [AXI30778] | RC Cars - AMain.com - AMain.com
Read this too.
Zero ackerman steering for you AX-10
CrawlCrest is offline   Reply With Quote
Old 03-04-2015, 07:58 PM   #10
Adjust the trim
Nugget04 is offline   Reply With Quote
Crazy steering with XR10 knuckles - Similar Threads
Heavy Steering Knuckles for Xr10 setecastronomy Axial XR10 3 09-25-2012 01:41 AM
Insane Steering angle on a mini... XR10 C's and knuckles T3rry Losi Mini-Rock Crawler 60 09-16-2012 02:51 PM
