03-07-2015, 12:45 AM | #1 |
Quarry Creeper Join Date: Nov 2013 Location: florence ky
| axle/beef tube options
I am wanting to solve the loose c-hubs and lockout issue's once and for all. What else is out there on the market beside burly tubes and beef tubes? Right now I am leaning towards beef tubes but the diy type I am really struggling to pull $60+ out of my wallet to buy these ridiculously simple peices of tube. Granted I have $1000+ in my rig |
03-07-2015, 05:46 AM | #2 |
Pebble Pounder Join Date: May 2013 Location: kinzers
| Re: axle/beef tube options
vp has clamping style c_hubs they are the only way to go but beef tubes are nice but don't really fix loose c_hubs I have 4ws and got beeftubes f/r and still didn't fix loose c_hubs then vp released ver.2 clamping c_hubs and that perm fixed prob don't feel bad I have over 5000$ into my fully custom wraith |
03-07-2015, 08:30 AM | #3 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
I've got over 3k into mine.. Mainly from trial and error. The VP clamping c-hubs look really nice. I'd lean that way my self if I didn't just order some D44s. Never could get the slop out of mine, even after replacing the c-hubs and tightening them with locktite'd screws. Stripped the plastic housings fairly quickly.. Personally I'd consider doing both. Not only do the beeftubes add weight and give you something else to mount to, they'll help prevent bending axles. Doesn't mean you won't twist them off tho. |
03-07-2015, 09:02 AM | #4 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
I have both beef tubes and VP clamping chubs. Let me say the connection is VERY solid. Regardless of whether you make em or buy em, some type of beef tube is needed if you wanna get the best out of the scale chubs. To me, the added weight is just a bonus. Without em, I'd be afraid of squishing the ends of the housing.... I have beef tubes and stock lockouts on the rear and theres no slop there either. Last edited by DeviledEggs; 03-07-2015 at 09:04 AM. |
03-07-2015, 09:55 AM | #5 |
Rock Stacker Join Date: Dec 2014 Location: South of columbus Indiana
I have beef tubes front only. Mainly for the attachment of the c-hubs.I used Loctite and they haven't come loose yet. The added non-rotational low weight is a big plus. It was a tight but perfect fit with the machining. Smooth install. Clamping along with this would be the ideal setup. I'm still running all plastic front until something breaks. Good luck on your choice. John |
03-08-2015, 04:15 PM | #6 |
The Wraith style beef tubes look simple to make, until you realize what a pain it would be to perfectly notch the tubes to clear the link mount bolts while keeping the bolts for the C-hubs correctly located. I gladly paid for my tubes. The tubes were a good part of the solution, but I found it necessary to drill/tap for 2 additional C-hub bolts. Did the same in the back for the lock outs. Thinks stay fairly tight now, but after several bash sessions I still find the occastional barely loose C-hub bolt. Way better than stock though, where they would all be loose after one pack. |
axle/beef tube options - Similar Threads | ||||
Beef tube help? | CoreyM | Axial Wraith | 11 | 10-09-2014 11:40 AM |
Beef in Yer Rear! to Tube? or NOT to Tube? | Big Tex | General Scale Talk | 29 | 01-08-2014 03:56 PM |
Beef tube ? | jcsaxial | General Crawlers | 3 | 08-28-2012 02:15 PM |
