03-23-2015, 10:12 AM | #1 |
Newbie Join Date: Nov 2013 Location: Dryden
| wraith build questions
So I just picked up a wraith chassis and axles First wraith so just curious what you guys would think of these components want to make a Solid ttc rig Hitec 7080 servo holmes hobbies waterproof bec (will it make that much of a difference over am xl5?) Savage flux shocks running droop Holmes hobbies 13t crawlmaster Pitbull xor rock beasts Picked up the aluminum knuckles chubs lower control arms and steering linkage and rc4wd punisher driveshafts already Any other must haves? |
03-23-2015, 10:38 AM | #2 |
RCC Addict Join Date: Feb 2012 Location: UK
| Re: wraith build questions
If it's a TTC then I assume you want power. The XL5 is only really 2s capable so I would not use that. |
03-23-2015, 11:48 AM | #3 |
Quarry Creeper Join Date: Mar 2014 Location: LI
Metal servo arm, and metal trans gear would be a good idea.
03-23-2015, 02:14 PM | #4 |
Ya forgot to mention servo horn is already aluminum Are the Transmissions that bad? |
03-23-2015, 03:43 PM | #5 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
| Re: wraith build questions No, but with a lot of power through them and the list of parts you have listed. With the big pitbull tires, makes the gears in the trans your weak point. If you are still running the dog bones it the front axle loose those and swap in some CVD style shafts when you do the knuckles. Move the battery up to the front under the hood. Last edited by BLKXJ 96; 03-23-2015 at 03:46 PM. |
03-23-2015, 03:53 PM | #6 |
Where are you at in michigan? Ya still have to upgrade the dog bones I will when they break |
03-23-2015, 03:57 PM | #7 |
| Re: wraith build questions |
03-23-2015, 04:07 PM | #8 |
Oh ok I use to live in Brighton any get togethers on here?
03-23-2015, 04:13 PM | #9 |
| Re: wraith build questions Keep your eyes peeled here: Midwest - Michigan at RCCrawler.com Im sure something will happen pretty soon, lots of guys finishing builds (including myself) and waiting for the weather to brake. we did quite a few runs last year. |
03-23-2015, 05:57 PM | #10 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Won't take long for the dogbones to break. Better go ahead and order some better shafts. x2 on the trans gears. Hot Racing makes a good, durable, cheap set. Bunch of guys in the Waterford area in Michigan. Others in Dearborn, etc etc etc.. |
03-23-2015, 10:06 PM | #11 |
Well the motor just took a shit on me so ordered the holmes 13t crawlmaster and xor rock beasts tonight |
Tags |
newtome, ttc, wraith |
wraith build questions - Similar Threads | ||||
want to do a build but have a few questions. | kpla51 | Axial SCX-10 | 9 | 09-14-2014 12:10 PM |
QUESTIONS! exo wraith build | mcrawlinslow | 2.2 Scale Rigs | 0 | 08-20-2013 08:07 PM |
some questions for the wraith pros on my upcomming build | champ198 | Axial Wraith | 15 | 05-07-2013 09:22 AM |
V3500's Wraith Questions and Build | V3500 | Axial Wraith | 1 | 04-26-2012 09:24 PM |
new build/first build lots of questions | the kid | Tamiya Clod Buster | 4 | 01-31-2007 03:05 AM |
