05-02-2015, 08:20 PM | #1 |
Newbie Join Date: Aug 2013 Location: canada
| Hobbywing esc questions
I got this esc HobbyWing eZRun-60A-SL Brushless ESC for 1/10 RC Car (Version 2) with a 13t motor Run great but when I go forward and want to go reverse very quickly it has a delay.. causing to much rollover on step hills ahah do yo got any tricks to delete this ''lag'' ( sorry my english is pretty bad)... If I cannot fix this, what esc should I buy ( ( cheapest please ) |
05-02-2015, 08:34 PM | #2 |
Rock Stacker Join Date: Dec 2014 Location: Tasmania
| Re: Hobbywing esc questions
Nothing you can do. Neither that esc or motor are designed or to be honest, any good for crawling as they are both sensorless, so will cog quite badly. for brushless its hard to beat the hobbyking x-car 120a esc and trackstar motor combo, somewhere around a 13.5t, give or take depending on desired speed and voltage. |
05-02-2015, 08:46 PM | #3 |
I joined the Band! Join Date: Dec 2014 Location: Earth
Have you tried putting it in "Rock Crawler" mode?? That removes the reverse delay on some ESC's.
05-02-2015, 08:59 PM | #4 |
| Re: Hobbywing esc questions |
05-02-2015, 09:29 PM | #5 |
| Re: Hobbywing esc questions Then you'll need to find an ESC with the instant reverse option. The reverse delay sort of defeats the purpose of "crawler mode". I'm getting ready to solder the motor and battery connectors on a Novak Crusher to go in my Wraith. It has instant reverse in "Crawler Mode", hill/hold brakes (drag brake) and a 5-amp BEC that should work just fine for me. |
05-03-2015, 05:09 AM | #6 |
I ordered the hobbyking x-car 120amp hope it will work fine with my 13t 3100kv ezrun sensorless motor I have the program card for my hobbywing 60a-sl Esc, will the card work with my 120 amp Esc ? |
05-03-2015, 06:29 AM | #7 |
Yes to both, but you need the usb programming dongle or hobbywing Lcd program box to change the firmware on the esc to get best performance. It's not going to crawl very well regardless of what you do with that sensorless motor though.
05-03-2015, 10:25 AM | #8 | |
| Re: Hobbywing esc questions Quote:
05-03-2015, 04:34 PM | #9 | |
USB Programming Adapter for Hobbyking X-Car 120A & 60A ESC | |
05-03-2015, 04:47 PM | #10 | |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
Has instant reverse, drag brake, etc. You can use the turnigy lcd box, or the hobbywing lcd box. Can also flash HobbyWing firmware. | |
05-03-2015, 05:19 PM | #11 |
yep, that will work fine. I run hobbywing modified firmware v3.something on mine and its excellent, extremely smooth low end, instant reverse, awesome drag brake/hill hold and zero cogging with a trackstar 10.5t motor. |
Hobbywing esc questions - Similar Threads | ||||
need help with hobbywing esc please | iluvny081 | Electronics | 13 | 03-29-2015 08:53 AM |
1st run, real glitchy, MMP and Hobbywing and other questions | IPT | Electronics | 17 | 05-28-2014 07:04 AM |
Hobbywing 3656SD 4000KV motor questions | IPT | Electronics | 0 | 05-14-2014 10:41 PM |
need help with hobbywing esc | sharpen | Axial Wraith | 8 | 06-07-2012 09:15 AM |
