Thread: high kv motor gearing question
Old 05-22-2015, 07:41 AM   #1
Default high kv motor gearing question
i would like to say thank you for any help ahead of time . I see alot of guys running above 4000 kv what do you do for gearing ? Also do you go out for 4 to 5 hrs or just ten min at a time? This is my first wraith but not crawler , i have a tekin rs and a 7.5t thunder power sensored motor laying around that i was thinking about trying in this truck but when our group goes out its for hrs . I dont want to have to stop all the time because of temp .
fullsizecrawler is offline   Reply With Quote
Old 05-22-2015, 10:10 AM   #2
Default Re: high kv motor gearing question
I ran a 4600kv 4 pole for a while, geared 64/11. 64t barely clears the front wraith length MIP output.
3200mah 3s lasted 40 minutes or so. Same battery is still going strong well over an hour at 3100kv.
I had problems overheating the sidewinder 3 ESC without a fan, didn't have issues after adding a fan.
You will break lots of parts, wraiths don't like 25mph. And carry a backpack full of batteries.
Or just get a more reasonable kv motor and don't worry about it.
maslin is offline   Reply With Quote
Old 05-22-2015, 10:30 AM   #3
I have no problems running a 4000kv motor. Haven't broken anything major. I use my truck for a trail / crawler truck.
My ESC is a MMP. Motor is a HobbyWing 4000kv 3656sd sensored motor.
Gearing is 60/12
I run mostly 3s batteries. 3700mah will last me for about 2-3 hours trail running.
The 3700mah 3s will last about the same for me as a 6000mah 2s.
The only concern I have about that motor is it appears to be a 2 pole.
Depending on your rig weight, a 2 pole might get a bit warm.
Gear is low to start and check temps.
robertjpjr is offline   Reply With Quote
Old 05-23-2015, 05:39 AM   #4
robertjpjr the truck is stock weight it just has a set of beadlocks that arent weighted . i got it in a trade
high kv motor gearing question - Similar Threads
Noob motor and gearing question . Wizardman Newbie General 5 10-31-2013 05:46 PM
Scx10 gearing and motor question jayuk022002 Axial SCX-10 1 12-28-2011 11:06 AM
20t motor and 45t motor gearing question? rcstrike Newbie General 1 11-16-2011 03:40 PM
Motor/Gearing question? JDeezie82 Electronics 7 03-04-2011 06:29 AM
Maxx gearing/motor question eric113 Newbie General 0 02-09-2007 10:44 AM
