05-25-2015, 08:34 AM | #1 |
Newbie Join Date: Jun 2012 Location: Houston
| Noob question.
Hi everyone I'm getting back into this after 3 years and can't wait!!!!! Just bought the crawlmaster pro 540 13t & BR XL ESC for my wraith. Will be running 3S battery Does anyone happen to know the shaft diameter for the pinion. 3 or 5 mm Also they say I have to use a 16T pinion with this set up because of heat. So 16/84 I assume is 48p. Is the 32p equivalent 16/56? Thanks in advance for helping out this noob! Last edited by haleymon; 05-25-2015 at 08:47 AM. |
05-25-2015, 09:02 AM | #2 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: Noob question.
Stock Wraith spur is 80 so if Holmes says use 16 pinion max that's a 1:5 ratio. In 32p if your using a 56 spur nearest to 1:5 ratio is an 11 pinion. I have the crawlmasters in my Sporty (16t) & Pro (13t) crawlers & can confirm they have the 1/8" (3.2mm) shaft. Last edited by altd896; 05-25-2015 at 09:07 AM. |
Noob question. - Similar Threads | ||||
Tire foam question. WARNING!!! Noob question! | tokdl | Tires and Wheels | 6 | 05-07-2014 10:55 AM |
Noob Question.. | thejunkman2005 | Electronics | 4 | 01-13-2012 05:57 AM |
Sorry if this is a noob question... | DSchulten88 | Scale Accessories | 9 | 11-19-2010 07:14 AM |
noob question | stack'o'rocks | Newbie General | 2 | 06-30-2007 09:35 PM |
Noob Question | 350jeepcj5 | Newbie General | 5 | 11-08-2005 08:11 PM |
