06-08-2015, 08:36 PM | #21 |
| Re: Droop kit recommendation
Not necessarily. By dropping the rear lowers at the axle, you've pulled back the instant center and increased anti squat. Raising the rear uppers will pull back/increase even further. Whether or not that is a good thing is entirely dependent on your setup. There are a couple of good threads about this in general crawlers. |
06-09-2015, 06:48 AM | #22 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
| Re: Droop kit recommendation |
06-09-2015, 07:59 AM | #23 |
Rock Stacker Join Date: May 2015 Location: Desert
Do these already come flipped on the spawn version? Or can i still flip those mounts. |
06-09-2015, 08:41 AM | #24 | ||
| Re: Droop kit recommendation Quote:
Just realized I misread your question. My 2.2 Wraith has the rear upper shock mount flipped, but nothing has been done to the front upper shock mount. Ride height was adjusted via the shock placement and preloads to bring it back level. Technically not the best way to set it up, but it does pretty good as it sits so I'm not too worried about it. | ||
06-09-2015, 09:52 AM | #25 |
Why are people so lazy these days if they want to limit droop go old school nitro fuel tubing on inside of the bore! I do that when I run Losi 4" BB's my Wraith I just did a rear droop plate to even the stance because my fronts are limited by a Bic pen retractable cut and measured spring inside the bore through the shaft internally.
06-09-2015, 09:54 AM | #26 |
Quarry Creeper Join Date: May 2013 Location: Knoxville
Who are you referring to? I want to lower my wraith not limit droop
06-09-2015, 10:46 AM | #27 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Droop kit recommendation - Similar Threads | ||||
Lift Kit or Droop Kit? | LBrown867 | Axial SCX-10 | 6 | 04-28-2014 11:42 PM |
Droop Kit | MattyO | Newbie General | 2 | 08-18-2013 05:06 AM |
Best droop kit | Chesebro | Axial Wraith | 6 | 06-25-2013 05:09 AM |
Droop Kit | Madkiki | Axial Wraith | 6 | 12-06-2012 04:30 PM |
Took Kit Recommendation Wanted/Needed | getoutandplay | Losi Mini-Rock Crawler | 3 | 11-29-2008 08:04 AM |
