09-16-2015, 04:04 PM | #1 |
Quarry Creeper Join Date: Aug 2014 Location: Indy
| Question about shimming HD gears
when shimming the pinion do I want it deeper in the case so the gears or kind of notchy or shimmed out to be more smooth?
09-16-2015, 04:16 PM | #2 |
RCC Addict Join Date: Dec 2009 Location: Laceys Spring, Alabama
| Re: Question about shimming HD gears
You can only shim he pinion in towards the ring gear. It should feel like the gears are making good contact but not binding. Use Traxxas TRA1985 shims
09-16-2015, 05:03 PM | #3 |
I put my shims between the putter pinion bearing and the mip shaft to keep the pinion from moving in. I'm guessing that was wrong?
09-16-2015, 05:52 PM | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Question about shimming HD gears Only if it's binding the bearings, if they still roll free and smooth you're fine. You want your gears and bearings smooth. "Notchy" or rough is bad, unless by notchy you're referring to a little backlash. A little backlash in the gears or end-play on the pinion is okay, it's better than tight and/or binding bearings and gears.
09-16-2015, 08:51 PM | #5 |
I've been putting a 5x11x5 ceramic bearing on the outside (driveshaft side) of the housing on all my axle builds recently (6 to be exact) and it seems to be doing the trick. I can't take credit for this, someone else posted this in one of the pinion bearing/bushing threads and I liked the idea so I gave it a try. All 6 have had zero notchiness and just the slightest bit of lash in either direction of rotation and they spin smooth as butter. I'll be sticking with this method. It's worked on stock AR60s, the new SSD D60 axles, and VP Curries with the same results. HTH
09-16-2015, 08:53 PM | #6 | |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Question about shimming HD gears Quote:
Shims between the bearing and MIP, usually takes 2 or 3, I use tamiya shims. Trying to avoid this. Still happens, but it takes a lot longer. | |
09-17-2015, 07:25 AM | #7 |
Newbie Join Date: Jan 2015 Location: Oklahoma
I put shims behind the outer bearing also. Just need enough shim to take up the in and out movement. |
09-17-2015, 08:27 AM | #8 |
Thanks for clearing that up. Its working great so far.
09-17-2015, 01:28 PM | #9 |
Pebble Pounder Join Date: Dec 2012 Location: Vancouver
I've shimmed the space between the mip end and the outer bearing. So far so good. The last set of bearings that were not shimmed wallowed themselves out but I caught it before it ate the ring and pinion.
09-18-2015, 09:18 PM | #10 |
Quarry Creeper Join Date: Jul 2014 Location: North Florida.
Im running DeLux mod'd housings and no shims needed, he built it In And Its Perfect.
Question about shimming HD gears - Similar Threads | ||||
Axial HD Diff Gears for Yeti - Shimming | LSXGMC | Axial Yeti | 6 | 04-19-2015 04:38 AM |
Shimming the diff gears | 95yjsahara | Axial Yeti | 11 | 03-29-2015 06:17 PM |
Shimming the HD Worm Gears | Del Monte | Team Losi Comp Crawler | 65 | 01-12-2012 08:48 PM |
Shimming gears | Josh_Br | Axial AX-10 Scorpion | 7 | 12-23-2011 01:25 PM |
Shimming | Jake | Axial AX-10 Scorpion | 13 | 03-18-2010 10:05 PM |
