09-27-2015, 12:41 PM | #1 |
Quarry Creeper Join Date: Mar 2010 Location: Reno, NV
| Electronic problem
My Wraith developed a new problem today when I first started it up. The throttle is acting strange. Give it forward throttle and it hesitates and doesn't have brake. Give it reverse throttle and it will continue to drive backwards slowly even after I let the trigger go. Anybody have a problem like this before? Help please! |
09-27-2015, 02:31 PM | #2 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
| Re: Electronic problem
What type of ESC and is it a brushed or brushless motor? Sounds like you might need to reprogram your throttle endpoints.
09-27-2015, 02:39 PM | #3 |
It is the stock ESC that came with it and I am using a brushed motor.
09-27-2015, 02:42 PM | #4 |
The Axial AE2
09-27-2015, 02:45 PM | #5 |
| Re: Electronic problem |
09-27-2015, 03:41 PM | #6 |
So I followed the steps on the link you provided and it seems to have worked! Thank you! Still wondering why this happened in the first place though? |
09-27-2015, 03:43 PM | #7 |
I was kind of freaking out because I thought my ESC just burned out .
09-27-2015, 04:04 PM | #8 |
I'm just glad to be of help As to why it occurred in the first place is difficult to say. I do a lot of troubleshooting for a living and when something odd happens once I put an x in the 'shit happens' box. If it keeps happening then it's likely an indicator of a bigger problem and worth looking into further. If the ESC was fried it probably would have let out it's magic smoke! |
09-27-2015, 07:06 PM | #9 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
I'm guessing you bumped the throttle trim knob on the transmitter off its neutral setting a bit to reverse. The esc needs to see a neutral signal from the receiver to activate the drag brake, sounds like it wasn't seeing enough to trigger the brake. |
09-27-2015, 07:18 PM | #10 | |
| Re: Electronic problem Quote:
You might want to find the center of that throttle trim and re-calibrate the ESC since probably calibrated to an off-center position. It won't hurt anything as-is but anytime you calibrate end points you should start with trims at 0. | |
09-30-2015, 08:56 PM | #11 |
The radio has a cover for all the trim controls so I don't think I messed with any of them but I do remember my radio falling off the back of my truck the last time I was running it so maybe that did something. Thanks for all the help and tips guys! |
Electronic problem - Similar Threads | ||||
Electronic problem | webster420 | Electronics | 25 | 09-04-2011 04:49 PM |
Electronic problem | 671offroader | Electronics | 16 | 06-19-2011 12:53 PM |
Electronic problem. | Burntnuts | Electronics | 3 | 02-20-2011 08:47 AM |
New Electronic Problem, Help! | MR. MAX | Losi Mini-Rock Crawler | 5 | 04-03-2009 07:57 AM |
Electronic Problem | dabomb5756 | Electronics | 10 | 12-23-2005 03:28 PM |
