11-30-2015, 09:37 PM | #1 |
Newbie Join Date: Nov 2015 Location: Cypress, Tx.
| How to get more articulation and add wheel weight???
So I just got my wraith last week and drove it for the first time today. I'm new to crawling (been driving a Trekker for two months, highly modified) but want to take it up a notch and go more Serious! I immediately know the changes I am going to make, like moving battery forward, I already lowered the shocks, I'm going to fab up a better steering linkage and other things, but what I want to know is how do I get better articulation out of the stock shocks? I am looking to make this a primo rock crawler. I'm interested in crawling only, so I want maximum torque and huge articulation! I know I need the ride height lower and more weight up front and out on the wheels! SO, what do you all suggest for better articulation, better low end torque (gear-wise) and how should I add weight on my wheels to get the weight out on the axles? On my Trekker I cut the Springs a little bit in order to lower ride height and also reduce the tension from the springs in order to allow the axles to flex much easier. It worked great! Would this theory work on my wraith to achieve the same results? Thanks anyone for your tips in order to help me make this thing a killer crawler! -Clint |
11-30-2015, 09:53 PM | #2 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
| Re: How to get more articulation and add wheel weight???
Well you can cut down the stock bump stops in the shocks, that's about it. Really more articulation isn't that useful, getting the weight as far forward and low as possible and minimizing torque twist is what's going to make the big difference. Also make sure to flip the lower link mounts if you haven't already.
11-30-2015, 10:55 PM | #3 |
The Wraith has plenty of articulation. More will only hurt performance. Flexing looks cool (apparently), but in excess is worthless. Before adding weight, move the battery under the hood. Then add small amounts of weight until you can balance the rig where the lower front links bolt on to the skid. You may find that you don't need to add much (if any) weight at all. For better torque, and less torque twist, either go with OD/UD or UD/UD gears in the axles. Some like OD/UD better, I prefer UD/UD. |
11-30-2015, 11:05 PM | #4 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
I've found that SD (standard drive) up front and UD in the rear works best for me. Having the front wheels turn just a bit faster than the rear really lets the front end pull through corners rather than the back wheels pushing you off your line. This is a moot point though if you're going to use a dig unit in which case I agree with the Duuude in going UD/UD.
12-01-2015, 08:05 AM | #5 | |
Thanks guys! Just trying to really learn all of the stuff...! | |
12-01-2015, 08:13 AM | #6 |
Pebble Pounder Join Date: Dec 2013 Location: yakima
UD = under drive gears. od = over drive gears. Their referring to the gears ( ring and opinion ) in the axle housings. Stock gearing is 38t/13t . under is 43t/13t and over is 36t/14t
12-01-2015, 10:33 AM | #7 |
| Re: How to get more articulation and add wheel weight??? ok, thanks for the information! that is exactly what I was wanting to know! So where would I get the 43t gear to replace in my rear housing? I will probably go with the Standard in the front and UD in the rear to achieve a slightly stronger pull in the front.
12-01-2015, 10:45 AM | #8 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
RPPHobby.com, CKRC, SuperShafty, etc.. Too much articulation will get you stuck and flipped over more than it helps. A good rule of thumb is a tire height of flex, and if you can get the lower links level with the skid that's an excellent ride height. It's better to drag the belly across rocks than to roll over or get a wheel hung up. |
12-01-2015, 11:03 AM | #9 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
I like the hd/ud setup in my wraith. It tends to help the front end stay planted on steep climbs. You can also rebuild your shocks with low rebound. A droopy setup seems to crawl best- if you dont mind a bit of belly dragging.
12-01-2015, 11:14 AM | #10 | |
| Re: How to get more articulation and add wheel weight??? Quote:
12-01-2015, 11:31 AM | #11 |
^^ Agreed. No sense in just upgrading the rear. Use the HD stock ratio gears in the front. Helical cut machined gears, better mesh.
12-01-2015, 12:48 PM | #12 |
| Re: How to get more articulation and add wheel weight??? I would love to look at doing this to my shocks, so how would I go about rebuilding my shocks in order to create more droop?
12-01-2015, 04:09 PM | #13 | |
My comp rig was set up SD/UD, and then OD/UD and yes, there was a noticeable improvement in steering and climbing. | |
12-01-2015, 05:42 PM | #14 |
| Re: How to get more articulation and add wheel weight??? Pull the shock apart. Refill em and let the bubbles rise out f the oil. When you go to tighten the caps make sure the shocks are fully compressed. Once back together the shocks should pull the shafts back in when you pull them out. You may also want a softer spring as well. |
12-01-2015, 06:34 PM | #15 | |
Newbie Join Date: Nov 2015 Location: cincinnati
Sent from my SCH-I545 using Tapatalk | |
12-01-2015, 06:48 PM | #16 |
| Re: How to get more articulation and add wheel weight??? Instead of the center of weight being in the center of the skid, if you can balance it out at the front of the skid where the links attach it'll crawl much better. Hopefully that explains it better without a picture?
12-01-2015, 06:50 PM | #17 |
Rock Stacker Join Date: Mar 2015 Location: Clarksville
With the comment about the links (correct me if I'm wrong) I'm sure he's talking about weight bias and adjusting what weight you currently have to move 70-75% of it towards the front of your wraith. When he says move your battery foward he's referring to doing the hood hinge mod where you take two small clamps from your parts tree and attach them to your hood and the bottom of the window frame tube. This allows the hood to hinge open just as a traditional 1:1. The battery lays on its side, width wise, along that same window frame tube.
12-01-2015, 06:50 PM | #18 |
Yeah but what do I move up there lol Sent from my SCH-I545 using Tapatalk |
12-01-2015, 07:17 PM | #19 |
I hack up the battery trays to fit on its side, in between the firewall and the rx box. IIRC, there are a couple of vendors that make drop in boxes for the front that makes it that much easier.
How to get more articulation and add wheel weight??? - Similar Threads | ||||
wheel weight vs knuckle or axle weight vs creative weight distribution | tech712 | Axial SCX-10 | 16 | 11-04-2014 01:04 PM |
To Add Weight or Not To Add Weight??? | JCSXJ | Axial Wraith | 7 | 02-16-2012 11:45 AM |
Another way to add weight | Failedabortion | Losi Mini-Rock Crawler | 4 | 03-22-2009 03:44 PM |
how much weight to add? | 84CUCV | Tires and Wheels | 7 | 03-03-2009 07:46 AM |
add wheel weight or not? your opinions requested | WRXronald | General Crawlers | 3 | 02-14-2006 05:57 AM |
