12-25-2015, 11:08 PM | #1 |
Pebble Pounder Join Date: Aug 2015 Location: Oklahoma
| Going for shorter wheelbase
As the title says, I want to shorten the wheelbase about 20-25mm in the rear. I've looked and looked and the only way I'm able to get the link lengths I'm after is by using upper links on bottom. Anyone else tried this before? Cause I've also been thinking of trying the high clearance uppers on bottom (lowers I run now catch on stair steps really bad) for a while now anyways. |
12-25-2015, 11:12 PM | #2 |
Quarry Creeper Join Date: Jun 2013 Location: Australia
| Re: Going for shorter wheelbase
Make your own links to whatever length you want. Very simple - anyone can do it. Buy some threaded rod from hardware store and some metal tubing to use as a sleeve over the threaded rod - add traxxas rod ends to each end and you have links made to suit. Sent from my iPhone using Tapatalk |
12-26-2015, 08:42 AM | #3 |
Can they be bent? I've seen that trick done but I don't remember anyone bending them.
Going for shorter wheelbase - Similar Threads | ||||
Will a Vanquish link set meant for a 12.3" wheelbase SCX10 fit a 12" wheelbase? | Derekuda | Newbie General | 1 | 08-10-2015 06:10 AM |
Shorter or longer wheelbase | Measuredpath | Tamiya CR-01 | 4 | 10-14-2014 06:30 PM |
Stock chassis to Chaotic chassis...shorter wheelbase...fixed | OhioCrawler | Axial XR10 | 34 | 03-20-2012 12:47 PM |
shorter wheelbase | bahogtubig | Redcat Crawlers | 3 | 12-14-2010 06:58 PM |
shorter? | JaKeLeE | General Crawlers | 6 | 07-09-2006 02:44 PM |
