01-15-2016, 10:36 AM | #1 |
Rock Stacker Join Date: May 2015 Location: Reno
| Flipping the skid plate around?
I was winding if you could flip the skid plate around to essentially running the drivetrain on the other side?
01-15-2016, 12:34 PM | #2 |
| Re: Flipping the skid plate around?
not sure why for but you should be able. the Ft/Rr axles can be re-positioned so the driveshaft(s) will align with the t case's output shaft(s). And the axle(s) drive direction can be altered by flipping the axle(s) ring gear (locker housing) 180* I know this because accidentally during assembly of mine I installed one of the axle's ring gears backwards. and then the front axle would pull forward... but the rear axle was running in reverse. oops... axle drive forward and axle drive rearward... is a problem !? Lol |
01-15-2016, 12:53 PM | #3 | |
| Re: Flipping the skid plate around? Quote:
01-16-2016, 08:32 AM | #4 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Depending on the front upper links your using, this won't work with stock or with the alloy type with fixed ends but would be OK with VP or any others using a revo style screw on end, instead of all that swapping around could you drill & countersink 2 extra holes through the servo plate so you can bolt your links to it instead. You'll need to rotate that end of the link to horizontal rather than vertical hence the need for revo link ends. You may need a washer or 2 between the link & the underside of the servo plate to keep the link end from binding on the plate. Edit: actually I just I realised I'm thinking of the scx10 servo plate which is bigger, the Wraith plate will be to small I think, could always cut a new servo plate though Last edited by altd896; 01-16-2016 at 08:36 AM. |
Flipping the skid plate around? - Similar Threads | ||||
Measurements for stock AX10 Transmission mounting plate/skid plate | Apoch | Axial AX-10 Scorpion | 5 | 04-09-2012 07:53 AM |
skid plate | ped453 | Losi Mini-Rock Crawler | 2 | 05-27-2009 11:28 AM |
Skid plate | Olli23 | Venom Creeper | 4 | 02-06-2009 04:45 AM |
Skid plate | YAKIMA RC RACER | General Crawlers | 0 | 10-08-2008 10:42 AM |
AX-10 skid plate | liltexmp | Axial AX-10 Scorpion | 1 | 04-15-2008 07:39 AM |
