01-29-2016, 11:37 PM | #1 |
Rock Stacker Join Date: Mar 2013 Location: Chesapeake
| Wralux in progress.
So I saw a picture of a Wralux and thought I would give it a go. So far I like it, but I will have to norrow the front, it rubs pretty bad when flexed out. It is also my first hard body, definitely a lot of work. Sent from my SM-G900V using Tapatalk Last edited by Scott410; 01-30-2016 at 10:10 AM. |
01-29-2016, 11:43 PM | #2 |
| Re: Wralux in progress. Sent from my SM-G900V using Tapatalk Last edited by Scott410; 01-29-2016 at 11:53 PM. |
01-31-2016, 12:15 PM | #3 |
Cut the front end and narrowed it last night. Sent from my SM-G900V using Tapatalk Last edited by Scott410; 01-31-2016 at 12:17 PM. |
01-31-2016, 04:05 PM | #4 |
Quarry Creeper Join Date: Feb 2015 Location: Norway
Intresting, got a wraith and a couple of hilux body's lying around.. Looking forward too see how this turns out, might have to do the same if it turns out good |
01-31-2016, 06:27 PM | #5 |
This is how I am hoping it will turn out. Sent from my SM-G900V using Tapatalk |
02-04-2016, 09:50 AM | #6 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
I dig it! Its like a Toyota on 1 ton axles. Or maybe 2.5 ton axles... and 54"s. I always thought the front axle looked far forward on the wraith and even moreso with that little hard body. I'd try and shorten the front wheelbase a bit to bring that axle back to the realm of semi-realism. Keep us updated. Im curious to see how this turns out. |
02-04-2016, 10:05 AM | #7 |
I agree with you 100%. I have been at a stand still the last few days though. Between kids and work I haven't had the time. I'm also going to do a tummy tuck modification and make some new links to bring the front end in a little. Sent from my SM-G900V using Tapatalk |
02-05-2016, 12:13 PM | #8 |
Ha! I hear you brother. It took me a week to rebuild the front diff in my Yeti. Finally got it back together to find a blown knuckle bearing. |
02-05-2016, 09:33 PM | #9 |
Well, I was able to get some more done tonight. First thing I did was fill in the hood gaps were I had cut it with some plastic epoxy. While that was drying I took my front lower links off and shorten them by 5mm, what I difference 5mm makes. Then I flipped the rear shock mount upside down and made a plastic link between them to add strength. Once the glue was dry, I test fit the body and had to do a little clearance work to get the body to fit correctly since I narrowed it. Here it is as it stands now. Sent from my SM-G900V using Tapatalk |
02-05-2016, 09:36 PM | #10 |
I also ordered the rear half of the body tonight. Can't wait until it gets here. Sent from my SM-G900V using Tapatalk |
02-10-2016, 09:10 PM | #11 |
Got the rear end portion today, I hope to have it installed this weekend. Sent from my SM-G900V using Tapatalk |
02-12-2016, 08:25 PM | #12 |
Quarry Creeper Join Date: Oct 2009 Location: Redwood City
Nice build! The pinched front is looking good. The inspiration pic is located here in NorCal. Keep it coming!
02-12-2016, 10:12 PM | #13 |
Rock Stacker Join Date: May 2015 Location: Reno
Awesome! Ive been wanting to do this for a long time and wondered how to go about it. Thanks for some more inspiration! |
02-13-2016, 07:25 AM | #14 |
RCC Addict Join Date: Feb 2008 Location: your back yard
Nice and something you don't see a lot of. I really like working with hard bodies and feel they give more of a realistic feel when driving technical sections but I never seem to be able to stop moding them.
02-13-2016, 10:54 AM | #15 |
Yeah, this is my first hard body and the body detail is crazy. I plan to get more done tonight, it has been really hard for me to work on this thing lately. I hope to have the bed installed be the end of the night. Sent from my SM-G900V using Tapatalk |
02-13-2016, 10:46 PM | #16 |
I got the bed installed tonight. Started with this. Ended up with this. Still have a ton of work to do, but I think it's starting to look pretty sweet. Sent from my SM-G900V using Tapatalk |
02-13-2016, 10:52 PM | #17 |
Rock Stacker Join Date: Jun 2009 Location: Bartlett
Looking good Sent from my iPhone using Tapatalk |
02-14-2016, 08:36 AM | #18 |
Rock Crawler Join Date: Aug 2011 Location: SB
Very nice work
03-10-2016, 09:42 PM | #19 |
Well, the project got put on the back burner for a little while, but here it is. It could use a little detail work, but it is pretty much done. Believe it or not, I'm not sure if I like it, might have to trade it off. Sent from my SM-G900V using Tapatalk |
03-11-2016, 06:03 AM | #20 |
Newbie Join Date: Jul 2015 Location: Land O Lakes, FL
looks awesome! I was wanting to do the same thing with my wraith. Did you use the Tamiya body?
Wralux in progress. - Similar Threads | ||||
Progress | LIFTEDscx1oWRANGLER | Axial SCX-10 | 2 | 03-09-2014 06:06 PM |
Progress II | ZoSo | Axial XR10 | 52 | 10-23-2012 09:44 AM |
K2-3S progress.... | bruiserin2002 | 2.2 Scale Rigs | 34 | 12-29-2006 09:03 PM |
k2-3L in progress | Cloak | 2.2 Scale Rigs | 11 | 12-29-2006 12:55 PM |
work in progress very,very slow progress! | rednekcrwlr | Tamiya Clod Buster | 6 | 12-18-2006 09:48 PM |
