08-23-2013, 02:44 PM | #1 |
Quarry Creeper Join Date: May 2012 Location: Industry
| Wraith tranny mirroring?
Use to do this with the scx10 but can it also be done with the wraith? Thinking I may have to get the scx10 tranny case to do so. Reason I ask is due to all the torque twist off the line. Any ideas? |
08-23-2013, 05:06 PM | #2 |
| Re: Wraith tranny mirroring?
Does anyone know?
08-23-2013, 05:19 PM | #3 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
| Re: Wraith tranny mirroring? |
08-23-2013, 06:01 PM | #4 | ||
| Re: Wraith tranny mirroring? Quote:
Quote: | ||
08-23-2013, 07:55 PM | #5 | |
Yes I could just use different shock oil but I was trying to fix the problem all together. But the real problem is the wraith tranny case has the dig option in the way. Plus in the end you won't be able to use your spur cover. Oh well. Sway bars it is. Thanks guys | |
08-24-2013, 06:14 AM | #6 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
I think running the diffs the rtr way and switching the esc to reverse helps a lot with torque twist. The motor and driveshafts spin different directions. Not sure if they spin the same direction when set up like the kit cause I never looked!
08-24-2013, 06:23 AM | #7 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
only if u put a stock scx10 transmision u cand o that.with the wraith transmision is imposible
02-02-2015, 12:24 AM | #8 |
Quarry Creeper Join Date: Jul 2014 Location: North Florida.
Leave the trans as is and just swap the spur shaft and motor plate around ?
02-02-2015, 01:38 AM | #9 |
03-17-2016, 10:44 PM | #10 |
Newbie Join Date: Sep 2008 Location: M
Just take the tube body off and turn it around. Then swap the power leads on the motor to get F/R right and move the knuckles to the other axle. This will let you lay down a good size battery on the lower chassis tube after you trim or cut off the dig servo support. This will help with torque twist and lowers the center of gravity a great deal buy moving the battery to the lowest possible spot on the chassis. As well as keeping more of the weight forward of the center point of the rig. |
03-19-2016, 08:04 AM | #11 | |
Why move the knuckles? | |
03-19-2016, 08:56 AM | #12 |
Quarry Creeper Join Date: Dec 2015 Location: United States
03-19-2016, 09:21 PM | #13 |
| Re: Wraith tranny mirroring? Well, I see it now. Guess that's what I get for trying to read stuff in the morning before putting my contacts in. |
03-19-2016, 10:04 PM | #14 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Underdrive gears and/or ssd high ratio tranny will help with your torque twist.
04-05-2016, 10:27 AM | #15 |
Say you can't. ? I beg to differ. |
04-06-2016, 08:00 AM | #16 |
Quarry Creeper Join Date: Feb 2014 Location: NNJ in the sticks
That looks like a SCX10 trans case. Yes you can do that but with the stock wraith with the dig trans you can't.
04-06-2016, 05:03 PM | #17 | |
So YES YOU CAN reverse it ! | |
04-07-2016, 09:34 AM | #18 |
Interesting, I stand corrected. I may have to try that just for fun. I can't do it with my existing AL case but I do have the old one in the parts bin. |
04-07-2016, 09:38 AM | #19 |
I could have kept the servo mount but with my battery mounted so low and back I had to cut it off.
Wraith tranny mirroring? - Similar Threads | ||||
Whats the deal with mirroring the tranny? | Famous112 | Axial SCX-10 | 14 | 03-30-2013 11:23 PM |
Summit Mirror?? (Like Mirroring the axial tranny) | mtnhrdgr2 | Axial SCX-10 | 3 | 03-04-2011 03:24 PM |
mirroring the trans | scoutkrlr | Axial AX-10 Scorpion | 2 | 01-14-2011 08:59 PM |
mirroring trans? | pontiacfreak | General Crawlers | 10 | 01-05-2010 07:20 PM |
mirroring an axial tranny | 92civic | Axial AX-10 Scorpion | 3 | 07-22-2009 12:21 PM |
