07-20-2016, 05:04 PM | #41 |
Pebble Pounder Join Date: Aug 2014 Location: Dunkirk, NY
| Re: Wraithzilla II Build... Well, Assembly really
Ok I need a little help. I am running the proline slash shocks on this truck and I installed the springs that came with them. I believe I used like 35-40w shock oil but when I drop the truck it just bounces. What springs/oil should I use to make the suspension soft. I want it to be like my race buggies where when I set it on a table the suspension compresses slightly. If it matters I am also running CI comp/firm all the way around and it will probably be just under 10lbs when I am done with it
07-20-2016, 05:29 PM | #42 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
My personal opinion is your oil weight is nearly twice as thick as needed in a crawler.
07-20-2016, 06:25 PM | #43 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
Did you vent the tires? The CI DD inner foams block the holes in the wheels and you need to put holes in the tires themselves.
07-20-2016, 08:32 PM | #44 |
So what kind of oil weight we talkin? Like 20w? What about the springs? They seem stiff. Any advice on which would be softer than what comes with the power strokes? I really think the thing is bouncing off the ground cause the springs are compressing at all when it hits the ground. I didn't vent the tires. I want to be able to run in water and not get a ton in the tires. They do seem to vent ok as is tho? When I squeeze them they expand right back out. I may still do it tho. Would I just pop 2 holes in each tire with a belt hole punch or something? |
07-21-2016, 06:33 AM | #45 |
Pick up the Powerstroke spring kit, that should get you dialed in. Losi 2.75 in springs from the XXX series could be an option as well. https://www.prolineracing.com/perfor...sortment-rear/ The oil weight will probably be difficult to nail down until you find the right spring combination. |
07-21-2016, 10:46 AM | #46 |
Newbie Join Date: Jun 2016 Location: Glen Burnie
| Re: Wraithzilla II Build... Well, Assembly really |
07-21-2016, 09:29 PM | #47 |
Sounds good ill pick up that spring set. Thanks
08-16-2016, 09:20 PM | #48 |
| Re: Wraithzilla II Build... Well, Assembly really Anybody have a suggestion on how to vent the tires while they are already mounted on the beadlock wheels? Can I just heat up a shirt hanger and melt a couple holes in the tire? I don't want to have to remove the tires from the wheels. They were a pain in the ass to mount and don't want to go thru it again at the moment
08-16-2016, 11:04 PM | #49 | |
| Re: Wraithzilla II Build... Well, Assembly really Quote:
09-06-2016, 10:04 PM | #50 |
Wasn't sure how this was going to work but the panels came out fitting perfect. A lot better than the ones I tried cutting out by hand. I took a bunch of measurements on the frame and modeled the panels in solidworks And water jet cut them from .025" thk steel. The only thing I am not sure about is how to attach some of the panels to the frame in locations that don't have nuts welded in (like the rear deck and some of the interior panels). How should I do that? Can I just use silicone? Like run a thin bead along the frame edge then lay down the panel? I don't really want to use tire glue and mess up the powder coat if I ever need to remove the panel. http://rs27.pbsrc.com/albums/c195/er...h=480&fit=clip |
09-07-2016, 09:32 AM | #51 |
Rock Stacker Join Date: Oct 2015 Location: Kingston, WA
Silicone would be your best bet. But it will come off eventually, that's the only downfall.
09-07-2016, 10:12 AM | #52 |
09-07-2016, 10:19 AM | #53 | |
09-12-2016, 07:11 AM | #54 | |
The other thing I am going to be working on is the vp light bar. I have they hey ok controller for it but I am wondering can I run it right off the main truck 3s LIPO or will I need a seperate LIPO for it? And if u can run it off the main LIPO will it drain the battery fast? I am also wondering how I setup my Futaba 4pls to switch it on and off with the heyok controller. Any help is greatly appreciated. Last edited by slapjack; 09-12-2016 at 10:37 AM. | |
10-04-2016, 10:40 PM | #55 |
Just a couple panels left to install skins on and I can finally take it out this this weekend. I like how it is turning out. The spawn driver sits up a little too high but oh well. And if I could do it over I would have mounted the light bar on the outside in front of the windshield instead of inside the cab. I wanted to protect it in rollovers but doesn't quite look right imo Last edited by slapjack; 10-04-2016 at 10:43 PM. |
10-07-2016, 06:20 AM | #56 |
10-07-2016, 09:28 AM | #57 |
Pebble Pounder Join Date: May 2013 Location: kinzers
awesome
10-07-2016, 01:11 PM | #58 |
Quarry Creeper Join Date: Feb 2015 Location: Norway
Looks great |
10-07-2016, 02:11 PM | #59 |
Newbie Join Date: Sep 2016 Location: vancouver
Nice job sir. I can only hope mine turns out half as nice as yours.
10-07-2016, 11:28 PM | #60 |
Thanks guys!
Wraithzilla II Build... Well, Assembly really - Similar Threads | ||||
Wraithzilla Texas U4 Style Build | WesTX | 2.2 Scale Rigs | 55 | 10-29-2015 11:09 AM |
Csnyder's GC3 Build + Assembly Tips | Csnyder | Losi Mini-Rock Crawler | 21 | 02-25-2010 07:15 AM |
