Thread: Hot Racing Trans Gears Question
Old 07-27-2017, 10:04 PM   #1
Default Hot Racing Trans Gears Question
Can probably guess....
I'm having finding a bearing that will fit into the gear pictured below. Anyone know the correct size off hand? Thank you a ton!
Cheddarcheesus is offline   Reply With Quote
Old 07-28-2017, 12:33 AM   #2
Default Re: Hot Racing Trans Gears Question
Stock bearing size is 5x10x4 & every HR gear set I've got (1 aluminium, 5 steel) has used the stock size bearing
altd896 is offline   Reply With Quote
Old 07-28-2017, 04:40 AM   #3
Fast Eddie sells a wraith trans bearing kit, all you need, about$7.00 IIRC
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 07-28-2017, 07:46 AM   #4
Hang up and Drive
Thanks guys! I have plenty of spare bearings but none of them fit so i didn't know if it was an odd size or not. Appreciate it!
Old 07-28-2017, 09:32 AM   #5
For you or anybody else that may come across this: The Axial part# AXA1218 if you wanted just the two bearings for the idler gear.
LANGER is offline   Reply With Quote
Old 07-28-2017, 09:34 AM   #6
That's awesome thank you!
Old 08-01-2017, 10:30 AM   #7
Another $2 gets you 10.
https://smile.amazon.com/5x10x4mm-Pr...eywords=5x10x4
Farabomb is offline   Reply With Quote
Hot Racing Trans Gears Question - Similar Threads
Hot racing diff gears jdmguy760 Axial SCX10 II 18 05-15-2017 07:45 AM
Hot Racing Light Weight Trans Gears Col_Sanders Axial Wraith 8 08-28-2015 07:53 AM
How to: Hot Racing trans case dockman Losi Micro-Rock Crawler 0 12-12-2010 09:22 AM
Hot Racing Worm Gears KBrog Team Losi Comp Crawler 69 08-26-2010 09:47 PM
