06-28-2018, 06:48 AM | #1 |
Newbie Join Date: Jan 2016 Location: Spain
| Rock racer suspensions
Hello all!! I'm doing some improvements in my Wraith in order to race it in rockracer competitions. My concern is the suspension... As I've some experience in buggys, I've a Mugen mbx7 r at home... and the suspensions are IPS in both axles. When you take it with your hands, and release it down to the floor, the suspension is very smooth. When you do the same with Wraith, it seems you are releasing a basketball ball. Not absorving at all! I've it in the softer position, I tried with many configurations, and it's the same!! I know that IPS are better for a smooth suspension but I guess that maybe I could do something to improve my solid axle suspensions. Almost all of the suspension work is done by the tyres! Any suggestions guys?? Cheers from Spain! |
06-28-2018, 09:42 AM | #2 |
| Re: Rock racer suspensions
The factory Wraith shocks are not what you want for what you want to do with the rig. But swapping the shock oil to some thicker oil and/or change the little discs out on the shock shafts to the ones with smaller holes if you still have the parts trees. The smaller holes will slow down the movement.
07-02-2018, 07:21 AM | #3 |
Noted bro! What oild would you choose for that porpouse? |
07-02-2018, 07:59 AM | #4 |
The thickest you can find. I bought a bunch of oil from a guy ‘getting out of the hobby’ a year or so ago. I don’t remember the number but it’s a Losi brand. Brake fluid for a car would work but, again, I don’t remember which is thicker DOT 3 or 4. Maybe even power steering fluid. But I would wait on finding some proper fluid. Count each drop per shock when filling.
07-02-2018, 08:13 AM | #5 | |
| Re: Rock racer suspensions Quote:
07-02-2018, 08:28 AM | #6 | |
Newbie Join Date: Aug 2015 Location: IL
Rc tech has lots of info on shock tuning. Such info is easy to find | |
07-02-2018, 11:07 AM | #7 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
I found my wraith handled better (at speed) with no oil in the shocks, compared to 30wt. Soaked up everything. With some light oil (10-15 with stock pistons) to and sway bars to control TT it would be great. Or, as already suggested, use your usual 30ish weight and widen the piston holes. |
07-04-2018, 03:10 PM | #8 |
Pebble Pounder Join Date: Oct 2012 Location: Georgia
| Re: Rock racer suspensions |
07-04-2018, 08:25 PM | #9 |
RCC Addict Join Date: Dec 2014 Location: So Cal
Is the spring rate where you want it? Too stiff? If fine, is the sag good ( you like the ride height, tires can drop a bit)? If all is well there, on to the oil. What weight oil are you currently using? If you don't know, 30 wt is a good starting point. How fast is your rig, can you suspension tune for the full range of speed or pick a happy medium? As you change things, note the changes, one at a time. Video you rig after the changes, what you think and what actually is are probably 2 different things. Its frustrating at first, be patient.
Rock racer suspensions - Similar Threads | ||||
I want a rock racer. Yeti vs Twin Hammers vs Gom vs Bomber vs Rock Rey | TIME MACHINE | General Crawlers | 27 | 11-20-2018 05:58 AM |
Losi Rock Rey 4WD Rock Racer Open for Pre-Order | RPP Hobby | RPP Hobby | 1 | 01-04-2017 06:18 PM |
Rock Racer to Rock Crawler Conversion | Orgnoi1 | Axial AX-10 Scorpion | 9 | 03-06-2010 10:07 PM |
