05-17-2021, 01:41 PM | #1 |
Pebble Pounder Join Date: Mar 2021 Location: Clinton
| Voltage cutoff on stock ESC
I am running a 2S lipo in a stock Spawn. Can someone tell me what the voltage cutoff is on the stock ESC?
05-17-2021, 07:50 PM | #2 |
Newbie Join Date: Apr 2021 Location: Keene
| Re: Voltage cutoff on stock ESC
I’ve never made it to cut off, do you have the manual still? Sent from my iPhone using Tapatalk |
05-18-2021, 08:01 AM | #3 |
| Re: Voltage cutoff on stock ESC |
05-18-2021, 12:34 PM | #4 |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
If I remember correctly, the stock ESC cutoff voltage is 3.6V
05-18-2021, 02:08 PM | #5 |
05-18-2021, 03:14 PM | #6 |
Ideally, storage charge is 3.8V, or 3.85V if you really want to get technical. You will see info on the forum from people who never storage charge and claim they have no problems with their lipos. Personally, I would check the voltage after reaching cutoff to confirm you are at about 3.6V and you would probably be okay for a week or so at that voltage. If you haven't used the battery by then, I would storage charge it. Just the way I would do things . . . . . . . . Edit: Did a little searching around and found this which would seem to support "store them at whatever voltage they are at". https://www.propwashed.com/lipo-storage-voltage/ I've also seen many "storage voltage no matter what" posts so it really is up to whatever works for you. Like everything, if you search the net long enough, you're bound to find information supporting your theory, no matter what. Last edited by nightcrawler48; 05-18-2021 at 03:32 PM. |
Voltage cutoff on stock ESC - Similar Threads | ||||
lipo cutoff for the stock rs10 esc | walterfellmeth | Redcat Crawlers | 14 | 05-29-2017 06:25 PM |
Stock low voltage cutoff settings | P-J | Axial Yeti | 6 | 02-05-2015 10:28 PM |
Lipo Cutoff Voltage.. | VotebanForgotHisPW | Electronics | 14 | 09-17-2011 03:55 PM |
stock esc voltage | greaser | Redcat Crawlers | 6 | 01-16-2010 05:27 PM |
Stock ESC max Voltage? | Paul97 | Losi Mini-Rock Crawler | 1 | 01-05-2010 06:14 PM |
