09-01-2010, 08:59 PM | #81 |
RCC Addict Join Date: Mar 2007 Location: MS Gulf Coast
Skins go good with the body color and the beadlocks! This is a great write up, very informative. This for someone like me who is going to be getting his first ever moa rig when I get my XR10. I noticed you suggested using a Rocker dig in one of your set ups. I've seen people disapprove of this unit, is it worth getting? It doesn't short out so the rear will only freewheel and not lock, is this right? |
09-01-2010, 09:01 PM | #82 | |
09-01-2010, 09:30 PM | #83 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
It will work in a losi moa though...pics were up on the second page |
09-01-2010, 09:41 PM | #84 |
Is there any other way to mount the Front Servo? Some way so it's not just hanging out front?
09-01-2010, 10:09 PM | #85 |
| I have not seen an immediate solution to that. Right now I don't see it as being a huge problem as there is no tie rod up front. If there was a tie rod to get hung up then I would feel a stronger sense of urgency to figure out an alternative.
09-01-2010, 10:16 PM | #86 |
I would think with only one side hooked up. It leaves a Huge gap for Rocks to get pinned between the Tire and Servo Horn, Jamming you up. It's something I notice right off the bat. Seemed like a Half ass design on the steering to me. I love the Steering Rod on the back side going through the Case, but the Servo placement and mount just seem like an after thought to me.... But it wasn't enough to scare me away from buying a XR10... I've talked to a few guys and they thought the same thing. |
09-01-2010, 10:20 PM | #87 | |
Between the tire and horn is no different than any other steering really. That doesn't worry me. | |
09-01-2010, 10:27 PM | #88 |
Wheels are on! HOWEVER! The Vanquish Products SSZ's will NOT work a 225 offset hub on these axles. The pocket on the back side of the wheel is not deep enough. I had to go to 350 hubs all the way around. I have seen these wheels modified to fix this problem but it requires machining. Pics in a few. |
09-01-2010, 10:30 PM | #89 | |
A rock jammed here not only hangs you up, but takes your Steering out as well. | |
09-01-2010, 10:34 PM | #90 |
| Internal Wheel Rings Now this is just a personal tuning method. I used a set I had made previously for these wheels. These rings are 3.75" OD and made from .125" polycarbonate. These keep the foam from folding over when side hilling, but they allow you still run a super soft foam. Again this is just something I have found has worked well for me. I only run these in the front wheels |
09-01-2010, 10:36 PM | #91 | |
I'm sure we will all play with steering options, look at how far Berg steering has evolved in the last 2 years | |
09-01-2010, 10:40 PM | #92 |
| Vanquish Products SSZ's |
09-01-2010, 10:51 PM | #93 |
Quarry Creeper Join Date: Mar 2009 Location: searching
looks awesome! do the wheel ring help with undercuts as well? |
09-01-2010, 10:58 PM | #94 |
09-01-2010, 11:03 PM | #95 |
09-01-2010, 11:03 PM | #96 | |
09-01-2010, 11:19 PM | #97 |
| You can't....... All that would do is push the servo into the rock harder. Since your tire would be trying to turn into the rock.making that Gap tighter. There has to be a better way to mount that servo. Come on Josh use that CAD program of yours and think of something. Unless you can't do it. John I figured you say choose a better line, But sometimes you know there is nothing you can do. |
09-01-2010, 11:40 PM | #98 | |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
It's going to get weird around here soon. I would just take a reverse. The build is great Harley | |
09-01-2010, 11:59 PM | #99 |
Driving home now, couldn't wait, had to go get some photos. Grabbed some city shots, didn't have any well lit rock.
09-02-2010, 12:09 AM | #100 |
Rock Crawler Join Date: Jan 2006 Location: Vacaville, CA
man this thing is pretty bad ass. Good job |
