01-03-2012, 05:37 AM | #61 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
| Re: an another one....XR10 BJ4
Sorry to telll you that's an ancient mod going back to the 80's (possibly beyond...)
01-03-2012, 06:14 AM | #62 |
Rock Crawler Join Date: Oct 2007 Location: south of France
nice to know but I never said that I invented something, I just said where I found this tip |
01-03-2012, 02:24 PM | #63 |
| Re: an another one....XR10 BJ4 full weight 101gr added each side in front and 14gr in the rear new test tomorrow |
01-04-2012, 01:59 AM | #64 |
Are you still on the same wheel widths and hubs?
01-04-2012, 02:36 AM | #65 |
0.7 width w/ 0.725 hub 0.850 hub in rear |
01-04-2012, 09:22 AM | #66 |
Rock Crawler Join Date: Oct 2010 Location: triad
| Re: an another one....XR10 BJ4 Wow, really?!! I'm running the same hubs and i think it's wiiiiiide! I just had them on my losi so i used them until i decided what to use. I will say that with this width i have some serious steering throw since the wheels don't hit the springs or anything at full lock! |
01-04-2012, 12:32 PM | #67 |
yes it seems wide, but w/ Dlux wheels you need 1/4" more length on hub so w/ Dlux wheel, running 0.725/0.850 it's the same than running 0.475/0.600 w/ SLW wheel |
01-04-2012, 12:48 PM | #68 |
| Re: an another one....XR10 BJ4 |
01-05-2012, 05:07 AM | #69 |
working on my steering... and waiting for some part |
01-08-2012, 05:06 AM | #70 |
add some bling |
01-20-2012, 01:17 PM | #71 |
OK !!! some parts arrive today so let's go !!! new axle case Vp link mount Ti shaft steering mod now waiting for some parts and I rebuild the rear axle |
01-20-2012, 01:29 PM | #72 |
Quarry Creeper Join Date: Sep 2011 Location: Spring Texas
| It s not so bling...I d like to put the same in my wraith because wheel weight is bad for CVD... Proble is, I think nobody make that.... --- I am here: http://maps.google.com/maps?ll=30.078705,-95.460040 Axial Wraith and Losi SCTE |
01-20-2012, 03:31 PM | #73 |
Pebble Pounder Join Date: Nov 2011 Location: Yucca Valley
From your pics it looks like you drilled your holes for the brass inserts all the way through your case, did you? I can see where it looks like they may interfere with your spool's side bearings, just curious because when i found this mod in harleys xr10 guide there wanst much as far as directions. I just did my axles but only let the bit go to the previous depth. Waiting on VP upper links to assemble extra housings I had bought so not sure how mine turned out just yet!! |
01-20-2012, 10:18 PM | #74 |
there's two holes that I drilled all way. but if you mount your insert carefully it doesn't interfere w/ the bearing I made the same w/ the previous case and it work nice Last edited by dude26; 01-21-2012 at 06:17 AM. |
01-21-2012, 04:17 AM | #75 |
I just got my new rear shaft !!! no more play !!! thanks Egressor, you make a ****in' great job !!! |
01-22-2012, 05:15 AM | #76 |
| Re: an another one....XR10 BJ4 Ready to go !!! current weight: 2342 Grs (5.16 lbs) still waiting for some part |
01-22-2012, 07:29 AM | #77 |
RCC Addict Join Date: Oct 2008 Location: Finland
Looking good! Where did you get those brass inserts from? Is there a source in Europe? |
01-22-2012, 08:01 AM | #78 |
Thanks I take my inserts from here: M3 BRASS INSERTS - PUSH IN INSERT FOR PLASTIC QTY: 25 | eBay but maybe find a source here in France... |
01-23-2012, 02:44 PM | #79 |
Rock Stacker Join Date: May 2009 Location: French
Nickel new cardan rear it looks solid
01-23-2012, 05:18 PM | #80 |
Rock Crawler Join Date: Feb 2010 Location: Chapin, South Carolina
| Re: an another one....XR10 BJ4 Man, this is making me want to get mine running again. I need money!
