Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: an another one....XR10 BJ4.2 !!!!
Old 12-02-2010, 10:54 PM   #1
Default an another one....XR10 BJ4.2 !!!!
Hi
I just sell my super Clod to make a 2.2, so the XR10 kit is my choice
here's my setup:
2 FX-R
CC BEC
Futaba S9157
HH 35T
Dx6i with A6110 Rx
Sedona
Nova foam
Lipo Hyperion 1100mAh (and waiting for some 900mAh)
at this time I'm just waiting for my motor plate (a friend making the 9mm mod for me)
I gonna change the steering system too
and just want to know if HH need some break-in or not ??
ps: sorry I'm french so I can't explain all I want....
dude26 is offline   Reply With Quote
Old 12-21-2010, 10:37 AM   #2
ok some stuff have be made... but no rock... the weather here is defenitly too bad....
have some BWD link
CO caps
made the steering mod
waiting for some JeepnDoug spring cup
and a BJ4 chassis.....
and thinking to put the lipo on the axle...
more pics (on the rock I hope) when the sun get back....
Old 12-21-2010, 11:14 AM   #3
TEAM MODERATOR
Reflection's Avatar
I'll say, I've never broke in any of my Holmes Hand wounds, and they are still kickin and running great after a couple seasons. BUT, I have broke in motors in the past dunking them in water for a few and they seem to do a little better than a non broke in motor of the same quality.
Better to do so, I think so. Necessary, not really.
Reflection is offline   Reply With Quote
Old 01-24-2011, 02:13 AM   #4
thanks for the advice Reflection
so I don't break-in my motor due to the fact that HH said he done it
so a little update
BJ4 chassis
Big bore in front (and in few time in rear too...) w/ CO caps
Losi gold spring in rear
Front case mod
Losi wheels (and in few times some Eritex... )
add some weight in front but looking for putting my batt in place...
Old 02-14-2011, 01:11 AM   #5
some new pics
and just a little vid (I put this rock in my garden...so I can crawlin' everyday )
thanks
Old 07-27-2011, 02:08 PM   #6
just a update after the BIG (french comp)
and here's my set-up
2X FXR
Castle BEC at 7.2V
Hitec 7980
Rover white
CI DD foam
Eritex wheel 1"
Dlux wheigt
VP knuckles
Hyperion 3S 900mAh
HH 35T motor
CI high clearance link (lower rear)
BWD link (lower front)
Axial link (up)
Losi shock (miniT spring front- losi gold rear)
DX6i radio
Old 07-27-2011, 02:13 PM   #7
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Some awesome rocks you have there! Looks like a fun rig
JohnRobHolmes is offline   Reply With Quote
Old 07-27-2011, 09:49 PM   #8
Nice rig I really like it. Its cool to see that RC crawling is so big around the world.
JRW7072009 is offline   Reply With Quote
Old 07-29-2011, 02:20 AM   #9
thanks
just a another pic w/ some other crawler (great driver, that's help me to learn !!)
Old 07-29-2011, 03:07 AM   #10
Its a HARDKNOCKZ Life...
HARDKNOCKZ's Avatar
Very nice. Your rig is looking top shelf brother.
J.D.
HARDKNOCKZ is offline   Reply With Quote
Old 09-08-2011, 07:21 AM   #11
Hi
just a update
new tires, now I need to find a good foam tunning
new steering link, made w/ 4mm steel and revo rod end
and new shock tunning
front: 30wt w/ RCP internal spring
rear: 30wt w/ mini-t silver spring
Now I need to test this... this what I gonna doing , when my lipo is ready
Old 09-08-2011, 08:08 AM   #12
I'm loving your rig! It looks very nice and you did a clean job on it!
MitchellY is offline   Reply With Quote
Old 09-25-2011, 11:01 AM   #13
Hi
a nice vid made by Cirederf (thanks again !! )
and some pics of today's training
and now it's time to work on it
I gonna change the motor, ESc and some other stuff
Fab
Old 09-26-2011, 03:11 AM   #14
nice playground
you may cut the tires for a bit more traction
EGRESSor is offline   Reply With Quote
Old 09-26-2011, 03:26 AM   #15
thanks
for the BC I gonna cut them, but I want to test it like that and found a good foam combo ...and a good way to cut it
Old 09-27-2011, 10:22 AM   #16
Hello Dude
Je ne savais pas tu avais 2 ponts avants , je viens de les voir sur les photos , quelle est l'avantage ?
Nice crawler
EL DI@BLO is offline   Reply With Quote
Old 09-27-2011, 11:25 AM   #17
hi Diablo
look at my build tread on french forum to see that ==> HERE
the advantage is more clearance, same geometry, and less binding for the shaft w/ the final gear (stock rear shaft is longer)
I always run the stock gear w/o any trouble
Old 09-27-2011, 09:08 PM   #18
Default Foams
what foams did you like in your bc?s also how do you like the internal springs up front?
kliff_klimber is offline   Reply With Quote
Old 09-27-2011, 09:18 PM   #19
How do you like the torque master sport motors?
CRAIGB is offline   Reply With Quote
Old 09-28-2011, 04:36 AM   #20
hi
I don't really like the internal spring, a little too firm for my truck. so I use miniT spring now (much softer)
for the BC, I use Sedona foam in front and CI foam 5.5 soft/soft, and both on 1" Eritex wheel, I just cut my front tire, so maybe need more test...
for the HH I can't say because until now I used some Integy motor and this was on my old Super Clod based.
but this motor are really smooth and have a lot of torque
and now I gonna test 2 Brood LE 45T (w/ 2 microsidewinder)
I hope all is right for the SMC (I gonna try to go there)
