10-21-2011, 07:39 PM | #21 |
Rock Stacker Join Date: Jul 2010 Location: crisfield
i like the wheels but id be scared water or dirt would get in there id put sum super thin lexan in there just to protect the foam. but thats just me the rig looks good |
10-21-2011, 07:46 PM | #22 | |
Looks good Stubs! Thanks for running them. I will have a post with more info about these in a couple of days. Quote:
When I first built these wheels I had to remove my tires from the other set of wheels I was running that had 3 tiny, drilled vent holes in them. When I took the tire off I was surprised to see that there was quite a bit of water in the wheel that I did not know about. It had been weeks since I was around water of any type. So, while these wheels potentially let water in, it also lets water out unlike a conventional wheel. Also, I just took my wheels apart after running a ton of packs through them. There was no dirt in there. If you look at what the foam is doing in his previous picture, you can see its pressed in there pretty good. The foam will act as a barrier by itself not letting dirt pass by. | |
10-21-2011, 08:42 PM | #23 | ||
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
10-22-2011, 08:01 AM | #24 |
i see ur point and thats a good one i know i have vent holes in the rims and my tires and its a pain with water so these might be the ticket im looking for! d-lux can u pm me a price i have a little idea i wanna try.
10-22-2011, 09:29 AM | #25 |
Rock Stacker Join Date: Jun 2011 Location: Martinez, CA
D-lux Can you pm me with a price too
10-22-2011, 01:04 PM | #26 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
| Yep, and Eritex did it before me. If you want to seal the foam, just wrap electrical tape around the standoffs. Punch holes in the tape to the desired tuning. |
10-22-2011, 04:46 PM | #27 |
10-23-2011, 01:38 AM | #28 |
Rock Crawler Join Date: Oct 2007 Location: south of France
great work Erik (as usual ) that's gave me the inspiration, I gonna try to do something w/ a friend (he's machinist) |
12-28-2011, 01:22 AM | #29 |
| Re: stubs XR back to stock build
I ordered a Y-Town secret agent chassis last week and decided to pull the cases off the FXR's while i waited for the chassis. Pulling the cases was easy i just hope i didn't mess anything up. Not sure if it loses any weight but it looks cleaner in the little chassis. The chassis is awesome! I have wanted a carbon chassis and have been waiting for this thing since they came out. The link lengths in the "secret agent" thread were really close but are not perfect for me because i have a front housing in the rear and run the front VP upper link mount backwards in the front. I also had to run the shock limiter internal in the rear not external. |
12-28-2011, 01:46 AM | #30 |
Rock Stacker Join Date: Oct 2009 Location: In the backyard
Man stubs has a secret agent...I have to get one too.
12-28-2011, 01:57 AM | #31 |
| Re: stubs XR back to stock build |
01-02-2012, 11:16 PM | #32 |
| Re: stubs secret agent
The chassis is great. The only thing i need to work out is a lifting i am getting on the rear. In an off camber drop it will hold a rear tire? The chassis feels good other than that and i am hoping i can get out to a familiar spot before i move to really test it. I am not sure how to explain it other than the chassis feels really smooth compared to any chassis i have ran. A couple pics from the byb gtg sunday. |
01-03-2012, 05:36 AM | #33 |
| Re: stubs secret agent |
01-03-2012, 01:36 PM | #34 |
RCC Addict Join Date: Jun 2009 Location: Australia
Just read through this now, a lighter weight XR sounds good and by the sound of it giving you good results. Ill be suscribing, thanks for the build thread so far. Sent from my GT-I9100T using Tapatalk |
01-03-2012, 08:06 PM | #35 |
I wanna be Dave Join Date: Oct 2007 Location: 801
Damn that's light Your already an incredible driver. I bet your local comp buddies are getting nervous now! What's your weight setup now? And how much weight? Hope to comp with you again soon? |
01-03-2012, 11:18 PM | #36 | |
| Re: stubs secret agent Quote:
Thanks! I am way to light right now. I am at 5 lbs even with D_lux knuckle weights w/ 1 0.100 ring (for a total of 2.5 oz) and 3oz in the wheels. So, 5.5 oz per side. Nothing in the rear. I like my truck around 5 1/2 lbs usually. Think i am going to throw the 0.300 ring back on and add 2oz on each side on the rear axle. I am moving to Florida in 2 weeks so it is east coast comps for me for awhile. The wife is cool with trying to plan trips back around big comps. The steering link i got from you at Nats is awesome by the way The old one was like an anchor and your link never catches on anything. It is scratched up but i have never once noticed it get hooked. | |
01-30-2012, 06:44 PM | #37 |
01-30-2012, 07:22 PM | #38 |
01-30-2012, 07:24 PM | #39 |
01-31-2012, 12:36 AM | #40 |
no talent hack Join Date: Feb 2007 Location: Redwood City
Were you able to get rid of the rear tire lift? What did you do?
