01-11-2012, 09:58 AM | #101 |
Rock Crawler Join Date: Mar 2009 Location: Irving Texas
| Re: Mark Reel's XR10 Build 11th place at nats |
01-11-2012, 10:37 AM | #102 | |
Rock Crawler Join Date: May 2011 Location: SoCal
| Re: Mark Reel's XR10 Build 11th place at nats Quote:
1. Put RTV under the nut and live with it. 2. Grind yourself a tapered nut 3. Carve a flat spot for the nut Edit: Finished. Went for #3. Used 3mm flatheads both sides. You wanna do this fully disassembled so you can see what you're doing and clean up the shavings etc. Drill the #2 hole from the nut-side because the nut position is more critical than the head. Last edited by WAM; 01-11-2012 at 12:35 PM. | |
01-11-2012, 01:19 PM | #103 | |
#3 is what i did just grind a little and even if its not perfectly flat the edge of the nut will bite in to the plastic locking it in place | |
01-11-2012, 08:23 PM | #104 |
Quarry Creeper Join Date: Feb 2011 Location: A stupid town
Looks sweet, im trying to build my xr up but takes way too much time lol just gatta do one little thing at a time i guess..
01-11-2012, 08:51 PM | #105 |
01-13-2012, 06:14 PM | #106 |
ok here is a detailed post of this mod that has allowed my stock gears to last over a year. the second screw is a 4-40 with a losi min alum nut. just tighten these snug do not over tighten them as the plastic will just keep giving a long screw was used for better viewing, use a short screw that comes up just past the gold alum locknut. also replaced the end of the axle (pic # 13) small 5 x 8 bearing to a Bushing (as i had one bearing explode on me and then break the gears. Last edited by mark reel; 01-16-2012 at 01:08 PM. |
01-13-2012, 06:23 PM | #107 |
RCC Addict Join Date: Jul 2006 Location: barstow
great addition to an already great build thread thanks for sharing all that info and pics mark
01-13-2012, 11:35 PM | #108 |
Now I get it. Thanks for the info and pics. |
01-16-2012, 01:08 PM | #109 |
01-16-2012, 02:08 PM | #110 |
Rock Crawler Join Date: May 2007 Location: Prescott
Wow all that is needed? All I did is assemble per instructions and drive. You must examine every so often to insure no bearings have come apart. I have been driving my original axles and gears for 1.5 years now with Brood 35t motors. I just checked the other day to prepare for the a Nats qualifier and all is good. The only exception I have done after 6 months of running stock is go with VP motor plates and bearings along with replace the outer bearing with a bushing since I have had constant bearing failure there.
01-16-2012, 04:13 PM | #111 | |
Hi Wink, i don't know that you have to do all of that, when i built it everyone was already breaking bearings and gears alot so i just took a look at what i thought was flexing and made it stiffer and havent had any problems since. See ya Friday | |
01-16-2012, 04:37 PM | #112 |
I like the rear axle mod I'm going to have to do that next time I have the axle off. |
01-16-2012, 05:07 PM | #113 |
Graet walk through on the "two screw mod." and just when I was debating going to a front axle in the back... Decisions decisions |
01-16-2012, 09:48 PM | #114 | |
01-26-2012, 08:19 PM | #115 |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
Thanks for doing the whole write up on the 2 screw mod. I just got done doing this tonight. I originally left my 4-40 screw as long as the one pictured above but found that with a 13 tooth pinion, the top of the screw rubbed against the motor. Not sure if it was going to give me trouble setting gear mesh but I went ahead and cut it down to make sure it wouldnt cause a problem.
01-26-2012, 08:39 PM | #116 |
| Re: Mark Reel's XR10 Build 11th place at nats If understand you right, that's the only bearing that's gone bad (just a little rough and noisy) on my low mileage rig to date. I replaced it with an Avid ceramic. Are ceramics enough of an upgrade to be up to the task?
01-30-2012, 05:51 PM | #117 | ||
so it would show up better. for some reason it would not let me add notes after each pic. or i would have stated that. Quote:
and alot of guys have got the ceramics and had no issues. | ||
01-30-2012, 06:31 PM | #118 | |
I would also highly suggest the brass inserts as well. | |
01-30-2012, 08:54 PM | #119 | |
GOOD POINT Shelby , now that i think about it more it is a really small bearing and i dont trust it either | |
02-26-2012, 08:15 PM | #120 |
New and improved LOWER CG 90% of the Knuckle weight is now below the axle and as much as it pained me to cut up the Green ano on the rear lock outs i wanted to lighten the back a bit. will post more when assembled |
