03-19-2012, 01:28 PM | #61 |
Quarry Creeper Join Date: May 2011 Location: Salt Lake City
| Re: Racer`s Y-Town Agent 86
Grats on the win Manu! great driving! looking forward to our next crawl together!
03-20-2012, 03:15 AM | #62 |
Rock Crawler Join Date: Oct 2010 Location: Switzerland
Here a small video from my Agent on the Redrocks. There will be more informations when i`m back home. enjoy it. |
03-20-2012, 03:54 AM | #63 |
RCC Addict Join Date: Jul 2009 Location: Farmington, NM
Man, that thing just works!
03-20-2012, 05:48 AM | #64 |
Nice driving, no wonder you won! |
03-20-2012, 07:27 AM | #65 |
RCC Addict Join Date: Jul 2009 Location: Shreveport, LA
| Re: Racer`s Y-Town Agent 86 woah. If that isn't a sales pitch for a light weight set up, I don't know what is.
03-20-2012, 09:18 AM | #66 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
I noted this in your vid section post, at 2:44 you can see the full flex at work, it's a prime example of why you don't need a coke tin under opposite corner wheels whilst the other two are still on terra firma, this rig has about a half a wheel dia flex and it works awesome It looks like you restricted the fronts a tad more than the rears so the rear has a little more float, is this right? |
03-20-2012, 09:26 AM | #67 |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
Great driving, great video, and a great individual to have representing the Y-TOWN team! Thanks manu. |
03-21-2012, 07:38 AM | #68 |
Rock Crawler Join Date: Jul 2009 Location: Wil - Switzerland
| Re: Racer`s Y-Town Agent 86 |
03-21-2012, 08:55 AM | #69 |
Thanks to all the answers in this thread. I`m back home and Rig is cleaned. Here are my Link positions ( front and Rear Linkmount spaced up 1/8") Knuckle weights are milled down about 4mm to get more clearance. Added some spacers under the spring cup, so i can add some preload to the springs with the short Mini T springs. Ride High ( 2.75"/ 7cm) Fully extended ( 3.55" / 9cm ) RTR Weight 4lb12.45Oz / 4.77lb ( 4.9 Oz Knuckleweights per side) Setup over view: Shocks : - SCX 10 Front : 10mm limiter outside , no Internal / Mini T Silver Spring 50 Oil / no preload - SCX 10 Rear : 13mm limiter outside, no Internal / MRC Silver Springn 70 Oil / no preload Shock Position: - Front : 3rd Hole from front - Rear : 2nd hole from back Link positions : - Front upper : At Axle Top hole on VP mount rised 1/8" / Chassie 2nd hole from bottom - Rear upper : at Axle Middle hole on VP mount rised 1/8" / Chassie 2nd Hole from Bottom - Rear Lowers : At the Axle mounted on the Shockmounts ( inside) removed Link mount Links : - Costum self Bend, measurements and bends are similar like the ones from Krawlfreak - (Have access to some Chaotic Agent links) i take a look at them and will report if there are adjustments to get to the same like mine. If there are Questions, let me know them. Last edited by racer_zh; 03-21-2012 at 09:01 AM. |
03-21-2012, 11:06 AM | #70 |
Rock Crawler Join Date: Feb 2008 Location: Dortmund, Germany
Hello, great infos Manu New Links are ready, can't wait to put the axles under the Agent. Greetings Frank Last edited by Dr.Frank; 03-21-2012 at 11:08 AM. |
03-21-2012, 11:22 AM | #71 | |
RCC Addict Join Date: Nov 2004 Location: union
| Re: Racer`s Y-Town Agent 86 Quote:
03-21-2012, 01:04 PM | #72 |
It's very interesting to see there's only 15mm chassis float, this must help suspension predictability I have to say this is one of my favourite threads, I'm learning a ton from your excellent info and revealing photos |
03-21-2012, 01:35 PM | #73 | |
for infos: fully Compressed is the clearance around 2.4" / 6cm | |
03-21-2012, 02:30 PM | #74 |
Awesome video. i really enjoyed the multi-angle of that same climb What is your foam seup? |
03-21-2012, 02:43 PM | #75 | |
Like Single Stage foams in my BCs. There are some advantages in undercuts, where Dualstage foams pull you backwards and this results in loosing grip in Front. | |
03-21-2012, 06:50 PM | #76 |
This is such a killer rig. Keep up the good work |
03-21-2012, 07:26 PM | #77 |
It's hard to tell from the pics, but is your chassis forward of the halfway point between the tires or is it centered in the wheelbase? Does that make sense? Jeremy had his 4.0 built with the chassis forward of the center at some point. Just curious if that is still how you guys are building these things. |
03-21-2012, 07:31 PM | #78 | |
it should be forward... the cab is directly centered on that particuliar point....if nobody has noticed | |
03-21-2012, 07:36 PM | #79 |
03-22-2012, 04:54 AM | #80 |
Racer`s Y-Town Agent 86 - Similar Threads | ||||
Cleaning agent? | Sixohh | Paint and Body | 3 | 09-13-2011 02:27 PM |
april 19th down town greenville hosted by hobby town usa | new2theclod | Competitions | 5 | 04-13-2009 05:36 PM |
Agent Fat Cat | DISTURBIN' tha PEACE | Traxxas Crawlers | 125 | 07-08-2008 02:13 PM |
