02-22-2012, 11:34 PM | #1 |
Rock Crawler Join Date: May 2011 Location: Cali/Korea
| Dual ESC vs. Single.
Hey guys, Deal with me, Im new, I also looked this up were I only found 1 thread on this topic. I have money, I dont have time, lol. I dont mind spending, with that out of the way. I am currently Running 1 FXR with 45T Holmes Handwounds with a DX3R driving it. I simply wanted to know if I should move 2 a dual ESC setup or stick to single. My rig crawls awesome with 1 ESC, why should I upgrade to 2? I know the advantages are to be able to tune each motor however, is it really used that much? Thanks, LIK Last edited by OFFROADRCKOREA; 02-22-2012 at 11:38 PM. |
02-23-2012, 12:03 AM | #2 |
Rock Crawler Join Date: Aug 2010 Location: Socal
| Re: Dual ESC vs. Single.
Absolutely. Get the second ESC. It is night and day difference in the capabilities of the rig. The problem is your radio though. You would have to upgrade to a 4 channel radio or do some searching to see if Losikid still offers the WantAmix adaptor. That adapter would mod your radio to allow you proportional control of both motors. If money is not an issue I strongly suggest looking into the 4pl or 4pk radios. I personally run the 4pl. it is substantially cheaper and does a great job. Looks like he is making some more adaptors but you have to get on the mailing list. Products - OverkillRC Last edited by dstrbd1; 02-23-2012 at 12:08 AM. |
02-23-2012, 06:58 AM | #3 |
You don't have to have a four channel radio when a three channel will work if it has the right mixing program. However, he is correct in that the DX3R does not support dual ESC mixing unless you use a mixing adapter like that made by wantasummit (or Losikid now). I used this for a while before changing to my 3PKS. I was using a Futaba 3PKS to mix the ESCs but eventually switched to a Futaba 4PL just because it was designed to use duals. I am more than pleased with the switch and can heartily recommend this radio. Now why duals? You have better control of the rear motor to front motor bias which allows you to dial out the Clod Stall when climbing and if used correctly it is very effective in comps. With a single ESC both motors are the same speed unless you gear the front with a larger pinion to eliminate stall. The DIG is full on or off. With duals you can dial in the drag brake to suit each axle, a plus for downhilling. |
02-23-2012, 07:15 AM | #4 |
RCC Addict Join Date: Sep 2006 Location: Depew
I have it and rarely use it much. But when I do need it, its worth its weight in gold. I would say I only need to touch mixing once or twice a comp.
02-23-2012, 10:36 AM | #5 |
RCC Addict Join Date: Aug 2009 Location: Earth?
| Re: Dual ESC vs. Single. |
02-23-2012, 10:42 AM | #6 | |
Quarry Creeper Join Date: Oct 2011 Location: Detroit
| Re: Dual ESC vs. Single. Quote:
02-23-2012, 11:17 AM | #7 |
Quarry Creeper Join Date: Nov 2011 Location: Thunder Bay, Ontario
the cost diff isnt too much
02-23-2012, 02:57 PM | #8 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
i would say hacked gt3b and dual esc's
02-23-2012, 03:17 PM | #9 |
Newbie Join Date: Mar 2011 Location: TX
4pl, that way you don't have any other crap laying in your rig or having to worry about something that was added on/modded. Futaba did it right from the start.
02-23-2012, 06:04 PM | #10 |
Hey everyone! Thanks for all the awesome replies! You've definitely helped not only me but loads of future crawlers! Thanks! LIK |
02-24-2012, 04:21 PM | #11 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
Late to the party, but Dual ESC's change every characteristic of the rig. Being able to run like 70% on the rear motor helps keep you always pulling and searching for traction while maintaining progress. Go for it and Practice a bunch. |
02-24-2012, 06:11 PM | #12 | |
Changed over to my 3PKS, much better proportional control but was a pain to program. Bought the 4PL and BAM that was it. Now it works just like I would like it to work. Money well spent and $35/RX is awesome. | |
02-24-2012, 06:26 PM | #13 |
Rock Crawler Join Date: Oct 2011 Location: smithville
I pay $10 |
02-24-2012, 08:44 PM | #14 |
Rock Crawler Join Date: Oct 2011 Location: minot
i second the gt3b hacked radio with dual fxr escs.
02-25-2012, 01:19 PM | #15 |
Newbie Join Date: Feb 2012 Location: So. Or.
Waiting for my gt3b hacked radio to show up |
02-25-2012, 05:08 PM | #16 | |
How's the reverse control on that 4PL working for ya? Ever tried using the Expo settings? The proportional setting on the DX3R are adjustable by changing the EPA's and steps. Im not saying your wrong or trying to get you to use a DX3R. I think a DX3R is just a better radio than a 4PL. Ive used both. Its just my opinion. Quote:
02-25-2012, 07:21 PM | #17 | |
Now what in tarnation are you rambling about reverse? Don't need no expo, I learned how to use the throttle and like the linear feel on all my radios. | |
02-25-2012, 07:45 PM | #18 |
I won todays club comp with a single esc/punk setup over a couple rigs with dual esc's. Just sayin...... I don't see the need for the dual esc's, but then again I know how to tune motors to get the performance I want.
02-25-2012, 07:51 PM | #19 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
lol on the 1 esc . i drive mine well to but im lookin for a cheep way to just try the 2 esc . on the losikid rado be sure u buy it from him cause he want hack a radio if you dont buy it from him . i have one an have ask. i dont want to hack it when someone knows how to do it an they just want good luck finding a wannamix as well at the end of the day piss on the 2 esc ill stay with my one an kick ass |
02-28-2012, 02:51 PM | #20 |
Rock Crawler Join Date: Jul 2007 Location: central PA
I run the Punk/DX3r setup with a og Sidewinder and I am so used to it with my speedy driving style it is honestly great. It would definately be cool to try the 4 channel setups but I know it would take time to master and even then Ill bet you can drive a 3 channel faster. Only reason Ill need a 4 channel is for when my cutting brakes are out |
Dual ESC vs. Single. - Similar Threads | ||||
Dual motor esc for single? | msmith0322 | Electronics | 3 | 04-26-2011 08:34 AM |
Dual ESC vs. Single ESC and Dig | zjguy721 | Electronics | 12 | 02-21-2011 08:08 PM |
Wiring up Dual 35 Tekins to a single ESC with Dig switch. | Bigend777str | Electronics | 6 | 10-11-2010 06:28 PM |
Dual or Single ESC | cmjomaha | Newbie General | 18 | 09-08-2010 10:13 AM |
Dual Single motor ESC? | CT9A | Electronics | 1 | 07-09-2007 12:20 PM |
