07-21-2012, 09:08 PM | #21 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| Re: Transmissions clicking...
That's what I was tryin to tell you to check. That bearing sits all the way to the extreme left of the shaft. You'll see the seat in both axle top & upper link mount. As far as what to buy...It can get expensive quick but if ya want some peace of mind, the VP motor plate, trans case & upper link mount will replace all of the problem bearings with larger, better quality pcs. Gears...RC4WD offers a stronger set for way less cheddar. There's other mods you can do that are cheaper that guys like like bushings instead of bearings but bushings wallow out & I didn't care for em. Different strokes & all that. You can search just a few XR threads & find different mods that guys like. J.D. |
07-21-2012, 09:41 PM | #22 |
RCC Addict Join Date: May 2012 Location: Folsom
The VP motor mount plates are a good buy the have bigger and better bearings in them that are less prone to binding then the stock plates and gears.
07-21-2012, 09:42 PM | #23 |
oh FYI if you go this route there's a minor mod you have to do to the screw so it doesn't rub your gear, you'll see it as soon ans you try to put it together.
07-21-2012, 09:47 PM | #24 |
Rock Stacker Join Date: Jul 2012 Location: Victoria Canada
Thanks again. I think I'll get all the above mentioned upgrades...
07-21-2012, 11:44 PM | #25 | |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
| Re: Transmissions clicking... Quote:
07-22-2012, 01:53 AM | #26 | |
J.D. | |
07-22-2012, 12:08 PM | #27 |
Thanks for the info guys. I ended up ordering the vp cases, plates and caps. Tops will be a bit down the road. Also grabbed the rc4x4 gear-sets....Come on Mr. Postman!!
08-02-2012, 10:21 PM | #28 |
Rock Crawler Join Date: Feb 2012 Location: OC
Just ordered some VP Bushings, didn't wana use the Traxxas bushings was afraid of the "softness" of them as i suspect that the material is not up to par. I think hardknockz is right and Ceramic or premium grade bearings are really the way to go...but i saw these and needed to try them....plus those Traxxas ones don't look like they are flanged.... axial, xr10, xr-10 |
08-03-2012, 01:23 AM | #29 |
Newbie Join Date: Nov 2011 Location: earth
Djmedic2008 had a build vid. that showed that bearing and another mod where you cut off part of a plate with a dremel.
Transmissions clicking... - Similar Threads | ||||
transmissions | some_guy | General Crawlers | 8 | 01-13-2008 07:36 PM |
transmissions for sw3 | Wicked_Jester | Tamiya TLT Crawlers | 13 | 06-09-2007 08:24 PM |
Transmissions | aussie_N_B | Newbie General | 2 | 09-18-2006 05:56 AM |
Transmissions, Transmissions! Pros, Cons, All different typ | kevinlongisland | General Crawlers | 5 | 06-21-2004 05:49 PM |
