11-11-2012, 10:29 AM | #1 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
| Frickn' Gearbox Problem, it won't shut up!
See for yourself.. DSCN0950.mp4 video by photobucketposting | Photobucket It makes this sound when i have gearbox closed up too, Why? (13t pinion) |
11-11-2012, 10:38 AM | #2 |
Rock Crawler Join Date: Aug 2010 Location: Surrey BC
| Re: Frickn' Gearbox Problem, it won't shut up!
i think the pinion is to high and when you place the gear in there it is contacting with the grub screw that holds the pinion on the motor shaft....try setting your pinion down a little further on the motor shaft and see what happens. the rc4wd gears have a bigger pattern thus sitting down closer to that grub screw.... and another thing could be that the pinion is a little worn and with it being a 13t its pretty small and maybe the gear mesh just isn't right with the gear. pretty sure thats your issue give it a try and let us know Last edited by scorpion_ax; 11-11-2012 at 10:42 AM. |
11-11-2012, 10:41 AM | #3 |
sounds like the grub screw to me too.
11-11-2012, 12:03 PM | #4 |
Yep, that was it. When i first set the mesh/pinion gear i set it so the pinion and "spur?" were flush, but i had to set it back about 1-2mm, so i lost a little gear contact but hopefully shouldnt be a problem. also you could tell, on the grab screw, the threads exposed were shiny and slightly smashed down. Thanks for the help! |
Frickn' Gearbox Problem, it won't shut up! - Similar Threads | ||||
Gearbox Strengthening | Lemonlegs28 | Redcat Crawlers | 14 | 09-15-2010 06:06 PM |
Really weird gearbox/motor problem | dont slow down | Tamiya Clod Buster | 8 | 11-15-2008 05:45 PM |
Gearbox Problem | MC_StinkyNuts | Tamiya Clod Buster | 8 | 07-14-2005 10:07 AM |
mammoth gearbox Qs | jeep_boy02 | Tamiya Txt-1 and Juggernaut | 18 | 10-19-2004 10:43 PM |
Gearbox problem | AFJ | Tamiya Txt-1 and Juggernaut | 5 | 09-04-2004 04:49 PM |
