Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: NB's SS >> DD Build
Old 11-20-2012, 04:42 PM   #1
Default NB's SS >> DD Build
Decided to change things up for the new year and picked myself up the DD Chassis.
VP everything except top halfs
Hitech 7950
dual micro mambas (micro sidewinders on order)
CC bec
rowdy axle battery mount (topless)
Brood 45T limited edition match pair (35T matched vapors will be ordered by weeks end)
4PK
Mayhem Evo wheels
shaved rovers all around
big bores (thinking about getting the proline powerstroke but not sure)
blue monkey rear weight system
VP front axle weight system
CI bent steering tie rod.
BWD servo mount and rear axle brace
RC4WD gears front and back
Exciter body painted by BC Paints
Probably missing a few parts but that's the list.
Just waiting on the Lundsford ti links to show up this week before I start trimming the body then it will be complete.
Planning on doing a re-wire when the micro's and broods show up and tidy thing up . but this is how it sits now.
-NB- is offline   Reply With Quote
Old 11-20-2012, 05:10 PM   #2
Default Re: NB's SS >> DD Build
Nice paint!
ROWDY RACING is offline   Reply With Quote
Old 11-20-2012, 11:34 PM   #3
I would skip the power strokes an go straight to the scx shocks.. I tried the power stroke.. there meant for scale, not so much for crawling or laying flat like needed with the DD chassis.. luckily a friend had a set an I didn't have to waist the money to find this out.. there no where near as smooth as the scx shocks an I use the plastic ones.. if I keep beating on them, I may have to put the aluminium bodies on them..
winnerone23 is offline   Reply With Quote
Old 11-22-2012, 05:41 PM   #4
hey brian scx10 shocks
newbe5.9 is offline   Reply With Quote
Old 11-22-2012, 07:32 PM   #5
Added to the list
Old 12-13-2012, 03:04 PM   #6
Aftre breaking a few links finally got this rig up and running. This rig side hills like no other. Ive only ran a few packs through it but I'm impressed.
Old 12-13-2012, 04:02 PM   #7
Looks good...but isn't it supposed to sit lower than that?
Harvo is offline   Reply With Quote
Old 12-13-2012, 07:42 PM   #8
watch this one in action it works pretty good but like anything else need some tuning
Old 12-13-2012, 08:31 PM   #9
Yes it is.
Smarten up NB.
Krawler Kev is offline   Reply With Quote
Old 12-13-2012, 08:48 PM   #10
I saw him running this thing today at tha Garage , looks killer .
Was working awesome , other than a little electrical issue maybe ?
You get that fixed brian ?
Crawler Ted is offline   Reply With Quote
Old 12-13-2012, 09:21 PM   #11
ya it should look the pic number 3
slowride1 is offline   Reply With Quote
Old 12-14-2012, 07:03 AM   #12
I still have to make some adjustments to the front lower links. I think they may be a tad short which is causeing the truck to sit a little higher than it should.
Got her sort Ted Thx, it was a 4pk prog/mix setting that somehow got messed with while I was setting up a different model.
In this pic it sits lower.
NB's SS >> DD Build - Similar Threads
Jeep scaler build and comp micro crawler build droopmodmrc Losi Micro-Rock Crawler 1 12-25-2012 12:34 PM
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ 53 willys General Crawlers 108 11-28-2011 12:42 AM
RcBros LCC Build, Hi-Res pics & More Build!! RcBro Team Losi Comp Crawler 30 06-03-2009 07:26 PM
Practice build before I build a real crawler. jm8881 General Crawlers 46 03-13-2005 09:21 PM
