12-15-2012, 06:45 PM | #81 |
| Re: ★★ The HARDKNOCKZ Switch ZERO ★★
Cool. Thanks for the reply. I was hoping to get some data showing that the motor is weaker. It's pretty much what everybody says but I never had any sort of decrease in power when I lathed mine down. Wonder if Jrh has a dyno? I would also like to see data compensating for the INCREASE in power since you lost weight. |
12-15-2012, 06:59 PM | #82 | ||
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| Re: ★★ The HARDKNOCKZ Switch ZERO ★★ Quote:
12-15-2012, 07:14 PM | #83 |
Rock Crawler Join Date: Mar 2009 Location: Irving Texas
I think you should Name this RIG............................................ Skinny Bitch on Fire !!!!!!
12-15-2012, 07:16 PM | #84 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
Soo would that bug now be considered a brushed pede?
12-15-2012, 07:58 PM | #85 | |
Uuuuuuuum....huh? You have to much sugar at yer baby girls burfday? Bubs & Sis were wound TIGHT for about 30 mins & passed out cold. | |
12-16-2012, 04:31 AM | #86 |
Newbie Join Date: Mar 2010 Location: europe:P
| Re: ★★ The HARDKNOCKZ Switch ZERO ★★ Knife Party - Centipede (Official Video) - YouTube (for those who dont know this is knife party who used to be Pendulum who made a song Tarantula) Felt to fitting to ignore;) Nice ride brah |
12-16-2012, 09:07 AM | #87 |
Well.......we braved the cold last night & cut some more weight outta honey boo boo's pooper. Steve over at VP offered to give my SLW's some light weight love awhile back but they're CRAZY BUSY over there this time if year & those RIDICKA-LICKA-LICKALOUS Currie axles have only added to the nuttyness. So I decided to just skinniefy em myself. Starting weight wasn't bad at 55 grams but there's definitely room for improvement. This is including hubs & all hub hardware but not rings. Once again I went to work with my trusty step bits. I just eyeballed the location of my holes & tried to keep em somewhat uniform while leaving a decent skeletal structure. I was able to remove quite a bit of weight & couldn't be happier with the results. 15 grams works for me. There's room for more material to be removed but I wanted to make sure to retain as much strength as possible. If it holds up as well as I'm sure it will...I'll probably "ventilate" em some more. Weight with aluminum VP rings is still pretty good at only 8 grams more. Troy (winnerone23) offered to hand shape some cool carbon fiber goodies for me after I gave him the BWD Baby Mantis chassis that Don asked me to build & test last year. I just didn't have the time & honestly felt conflicted since I'm a Chaotic driver. Anyways...he cut me a couple of different servo guards, rear axle braces & a set of SLW rings in red CF. These things are purty cool. They ARE hand cut & the quality of the CF isn't the greatest so they're a little rough. I was honestly concerned with strength issues because they're a skinny whiddle piece. Weight savings you axe? Well....the CF rings add an additional 3 grams of savings. Plus...they look purty cool. But alas...my concerns with the durabilty of these rings turns out to be warranted. While testing...my rig took a decent bounce while dropping out of a crevice & cracked the passenger rear outter. Again...these were handcut with a router & Dremel & were made from some VERY thin CF. At this point...I don't see a real advantage to running CF rings. I know that every gram counts but at only 3 grams per wheel, I'm not digging the trade off of weight versus my peace of mind. In order to get the strength up in CF, we'd need to add some mils in thickness which will obviously add weight. The red CF IS groovy tho. I also started working on some new Boss Claws last night but the bitter cold proved to be too....um....bitter.....&......cold. I'll have some new parts to test coming from a new & very innovative company called "The Fifth Dimension" that I think will greatly improve the overall performance, looks & adjustiblity of a rig. BTW....I think I finally figured out my phone camera so HOPEFULLY every pic wont have a different visual temperature from here on out. Actually...I guess I could use the GoPro & have REALLY disco pics. That's all for now cats-n-kittens. Stay tuned for some new parts & groovy tech. J.D. |
12-16-2012, 09:19 AM | #88 |
I like the new name...."honey boo boo".... "Bitter cold"....you mean like 50*? |
12-16-2012, 10:18 AM | #89 | |
Hey for "skinny bitch on fire" you could just not run rings and glue the tires to the rim !!!! and save more with out the ring or hardware, drop down to three bolts holding the wheel offset adapter on and use alum. screws... been running this way for years and no issues. you can get de-bonder so when the tires are warn out they can be taken off. | |
12-16-2012, 10:47 AM | #90 |
Rock Crawler Join Date: Jul 2012 Location: Long Island, NY
Lose a few more grams by putting smaller holes in between those bigger holes? I'm thinking about doing this myself. I'm going to be doing a tear down on mine over Christmas break and I'm going to nut up and drill my SLWs. Mostly so I don't have to cut holes in my tires. Keep them pic's coming man.
12-16-2012, 12:32 PM | #91 | |||
Yup. 50 degrees & Im a shiverin little boy. We actually gotta teeny bit of snow the udder day so its gettin chilly. Remember...not ALL of Cali is beach front land just like not all of Texas is full of cows, shit kickers, chewin tobacky & bolo ties. Just MOST of it. YOU obviously live in the OTHER part of Texas full of plaid cargo shorts, argyle socks, flourescent colored running shoes & sideburns. Quote:
Thanks for posting that twice. I woulda missed it if you'd only posted it once. Texans Quote:
J.D. | |||
12-16-2012, 12:44 PM | #92 | |
12-17-2012, 12:03 AM | #93 | |
Also, I think ur scales broke.. or maybe 2 backside rings on that there scale.. I had a 6 gram savings with the CF rings.. 24 grams would be worth it.. oh well, back to the drawing board.. new company to get colored carbon from anyways. The wheels can take some more.. I started with 6 holes an now run 12 holes.. thinking of goin up a bit size.. close to tbe same weight with my slw as my dlux wheels.. good stuff so far, keep it up! New ring comin... | |
12-17-2012, 09:37 AM | #94 | |
If you look really close...you can see em mounted up in the video posted here in this very thread. I'll grab some pics of the busted ring for ya tho. Thanks for hookin it up. Lets see whatcha come up with next J.D. | |
12-17-2012, 11:44 AM | #95 |
Fifth Dimension sounds like some cutting edge future ish right there
12-17-2012, 04:57 PM | #96 |
Made a slight change to the size of the inner texture. This is the awesome-sauce hi-res copy that really shows the attention to detail. Last edited by Wicked Monkey; 12-17-2012 at 05:00 PM. |
12-17-2012, 05:04 PM | #97 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
looks sweet mike
12-17-2012, 05:06 PM | #98 |
RCC Addict Join Date: Jan 2009 Location: O.C
Just did the drilling the holes in the SLW's mod last week. I like the sexy skins too!
12-17-2012, 05:08 PM | #99 |
| Re: ★★ The HARDKNOCKZ Switch ZERO ★★ |
12-17-2012, 05:41 PM | #100 |
Rock Crawler Join Date: May 2011 Location: Cali/Korea
WoW awesome build so far brother, let me see those pics of those red CF rings from Winner, im thinking of picking some up. Also when are you gonna show those badass skins on your rig? LIK |
★★ The HARDKNOCKZ Switch ZERO ★★ - Similar Threads | ||||
Light Switch for Your Scaler - Firmtronics RC Switch Review | roktoy | Electronics | 29 | 09-15-2015 02:37 PM |
==HARDKNOCKZ Switch Teaser== | HARDKNOCKZ | Videos! | 15 | 07-24-2012 03:27 AM |
HARDKNOCKZ Chaotic Special makes a SWITCH | HARDKNOCKZ | Axial XR10 | 166 | 02-23-2012 09:04 PM |
