01-08-2013, 12:37 PM | #1 |
Rock Stacker Join Date: Nov 2012 Location: north augusta
| xr10 steering help!
hi guys,i have a xr10 that i built and i wanna know what kind of c hubs and knuckles i should get. i watch medic and teds garage alot i see that there xr10 have alot more turning radius! ive heard vp is the way to go i just wanna get as much info before i buy,i will be doin comp so i need to know what u pros are running...i also want a bta kit as well..any suggestion?
01-08-2013, 01:19 PM | #2 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
| Re: xr10 steering help!
Vp chub and knuckles, chaotic or vp steering tie rod
01-08-2013, 01:22 PM | #3 |
Quarry Creeper Join Date: Oct 2012 Location: Sweden
If you have stock wheels you will need wideners or get new wheels The original hubs and knuckels will give you 45degrees streering angle, but the original wheel will rubb the links and or shocks if you dont get the wideners Might be hard to se, but the first line is 0 steer, second, full steer without wideners, third with 15mm wideners, stock wheels, stock knuckels and stock hubs http://postimage.org/image/an8p62l15/ Last edited by BliB; 01-08-2013 at 01:32 PM. Reason: added image |
01-08-2013, 01:48 PM | #4 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
| Re: xr10 steering help! |
01-08-2013, 02:54 PM | #5 |
But he still need new wheels or wideners, 58 will not be possible with stock wheels without wideners unless he removes lower links and shocks
01-08-2013, 04:26 PM | #6 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
Hey, I comp at Ted's garage, i know first hand, most of us use VP knuckles and C's with a VP or chaotic tie rod, but to run the VP knucks, you will also need narrower wheels as well, as mentioned in this thread.
01-08-2013, 04:32 PM | #7 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
You can also narrow the stockers to work. Pretty easy to do.
01-09-2013, 05:59 AM | #8 |
01-09-2013, 01:23 PM | #9 |
01-09-2013, 02:58 PM | #10 |
Yeah i know, but my search skill is not that good, cause i haven´t found what i´m looking for, or maybe i´ve found to much so i forgett what i´m looking for ;)
xr10 steering help! - Similar Threads | ||||
Xr10 steering issue | cmyers1 | Axial XR10 | 10 | 10-11-2012 03:34 PM |
Throttle cutting out on XR10, but not steering? | generalee7 | Electronics | 11 | 12-01-2011 10:04 PM |
XR10 Steering Link Length | Szczerba | Axial XR10 | 5 | 11-23-2011 03:47 PM |
XR10 Steering mod | jakesy | Axial XR10 | 14 | 04-14-2011 11:07 AM |
