Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Upgrading a stock XR10 - a challenge
Old 09-25-2016, 01:39 AM   #1
Default Upgrading a stock XR10 - a challenge
I've just bought a stock XR10 that need an upgrade.
What i want is a new chassie, dual ESC and knuckle weights.
I am on a thight budget and need tip on what to buy.
What's the cheapest way to do this and still get usefull performance?
Desmo is offline   Reply With Quote
Old 09-25-2016, 08:46 AM   #2
J21
Default Re: Upgrading a stock XR10 - a challenge
I started out trying to save money as well but it is hard. the best way to save money on the parts is to have patience to find them used. Check the classifieds often as good used parts go quick. If you don't want to wait you will probably have to pay play unfortunately. Holmes Hobbies (HH) esc's and motors are top notch and have a few options for dual esc. I would go with the dual mini. Castle Creations is another good choice and is available from HH. Dlux is about the only option for axle weights unless you find some used ones. I'm no expert yet but this is what i have found.
J21 is offline   Reply With Quote
Old 09-27-2016, 07:29 AM   #3
What about the stock gears in the axle? Do i need to change them? And if so what do I buy?
Old 09-27-2016, 08:13 AM   #4
Custom Carbon Fiber
Robbob's Avatar
The stockers will hold up for some time, you could even do the 'two bolt mod' to the rear to help. If you search the forums for Mike Reel you can find the orginal post about the mod.
For fun crawls or just driving around theyre fine - if you start binding the truck up and really putting some twist into the axles youll blow the bearings or gears if not both.
You can still buy the Axial HD gears separately - I would get the locker and the smaller gear on top of that first. You can also buy the Hot Racing gears, stock on those is sometimes up and down.
Robbob is offline   Reply With Quote
Old 09-27-2016, 08:32 PM   #5
Really there is only 3 gears you need to worry about breaking in both axles... the small 12 tooth in the gearbox, the 22 tooth above the spool will break. There are traxxas bushings you can put in the gear box because the bearings fail immediately. The biggest thing will be keeping the axle halves from splitting, once it splits because the screws are threaded into plastic then the gears jump and snap! even on carpet. If it will hold up on carpet it will pretty much hold up on carpet I have everything you need. brass inserts, 30mm long bolts to run all the way thru the rear axle from top to bottom, better chassis, cheap links that are not ti. that you can do yourself. pretty much what Robbob says but I already have everything together
barrybelvedere is offline   Reply With Quote
Old 09-28-2016, 01:43 AM   #6
Thanx to Robob and barrybelvedere.
I have ordered the firestarter chassie from a local Company X3Mcrawl.
But the other mods sounds interesting. Do you have a website barrybelvedere?
Old 10-09-2016, 03:22 AM   #7
Is the Hot racing big bearing gear box worth spending money on?
Old 10-13-2016, 04:22 AM   #8
snapon boy's Avatar
I think berry's on Facebook but I haven't found him yet
149 r/c worx team driver
snapon boy is offline   Reply With Quote
Old 01-17-2017, 11:38 PM   #9
Desmo, have you completed your build? I am slowly pushing along and breaking crap as I go. Just asking cuz I haven't seen any new posts.
Nastyman211 is offline   Reply With Quote
Old 01-18-2017, 01:14 PM   #10
It's not completed, still need some tweaks. But it has been in use.
[ATTACH][/ATTACH]
Old 01-18-2017, 01:43 PM   #11
Rig is coming along nicely!!
Sent from my HTC One M9 using Tapatalk
dasco is offline   Reply With Quote
Old 03-22-2017, 03:11 PM   #12
Was time to get the firestarter XR out of the shelf today.
Upgrading a stock XR10 - a challenge - Similar Threads
Upgrading Two Stock SCX10's: 1 Dingo kit, 1 Deadbolt RTR Axial Rose Axial SCX-10 3 09-05-2016 02:14 PM
Upgrading from the stock SCX10 20t/Diagnosing an issue CHawk68462 Electronics 7 07-10-2013 11:00 AM
Upgrading my stock clodbuster. Kbabiasz Tamiya Clod Buster 6 10-07-2012 04:47 PM
Will upgrading steering links kill stock servo? ApeMac15 Axial Wraith 15 04-26-2012 07:50 AM
upgrading stock ax10 electronics, brushless or brushed and what systems? flatland13 General Crawlers 7 06-28-2010 12:57 PM
