11-30-2015, 06:46 AM | #1 |
Newbie Join Date: Nov 2015 Location: In a house
| New Owner with Questions
Hello all, I just bought a used Yeti XL. It was a RTR kit but the owner did a number of upgrades such as suspension link stiffeners, upgraded steering servo, and sway bar, plus it came with a lot of extra parts he had stockpiled. He had ran it both on 6s and 4s...I am only going to run 4s. I put some Traxxas 17mm hub adapters on it as I did not like the small serrated wheel nuts. After running it for the first time, I found I have a slightly bent slipper shaft, which I have parts for and other than that it seems to run fine. I'm not hard on my RC stuff (I have a Summit converted to brushless, and a slash 4x4) and the 4s performance was fine for me. What parts should one replace to improve the steering on this buggy? It actually steers okay but it does seem loose and flimsy...so I'd like to tighten that up if possible but I could use some advice on what parts should be upgraded. Thanks. |
11-30-2015, 08:04 AM | #2 |
Rock Crawler Join Date: Jul 2015 Location: McKinney, TX
| Re: New Owner with Questions
Congrats on getting a pit bull on cocaine. Welcome to the world of the YXL. Aluminum Steering Bellcrank /w Bearing & Steering Posts For Yeti XL 90032 Dhawk from Ebay will help the steering. Since it's RTR it may have plastic turnbuckles and a plastic servo rod. GPM makes a metal servo rod (easy to make yourself if you have some Traxxas rods and ends). Getting the kit, GPM, or Vanquish turnbuckles will help take some play out. I recommend getting the Dhawk bulkhead, rear driveshaft, and spacer for the diff pinion. You can also shim the front hubs and axels to remove some slop. I would also recommend taking a look at the front and rear diffs. Check the pinions and ring gears for wear and/or flat spots. If it's stock, the plastic spacer on the pinion may wear out. If it's still running the stock plastic order the Dhawk replacement. When the stock fails you'll end up with a headache. If you have the Castle Link system you may want to tweak the punch control on the ESC. That'll help save the diffs and wheels. It'll never turn like your Slash. The YXL is a different kind of RC. It's a lot of fun to drive but it takes some finesse to have fun w/o breaking stuff. My son has a Slash 4x4 I modded into a monster buggy and that thing is bullet proof. Even with a 10 year old bashing it to hell and back nothing has broken. The YXL is by far my favorite RC to drive. It's a crazy beast and a lot of fun. |
11-30-2015, 09:07 AM | #3 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
There ya have it
11-30-2015, 08:13 PM | #4 |
Thanks for the help. I'll look into rounding up those steering parts. It seems the previous owner upgraded the turnbuckles.
11-30-2015, 08:48 PM | #5 |
Pebble Pounder Join Date: Oct 2015 Location: Portland
Amazon has them or eBay But they are good upgrades Also the Gpm rear drive shaft |
12-09-2015, 09:32 PM | #6 |
I had the transmission apart, cleaned, and regreased it, put in a new slipper shaft and slipper, changed the steering servo, put in a cc BEC and an RX bypass. I've got the Dhawk steering stuff coming as well as a Dhawk driveshaft as I noticed mine had a wobble. Oh well...getting to know the buggy somewhat as a result of this work.
New Owner with Questions - Similar Threads | ||||
One happy owner with a few questions | mond | Axial Yeti XL | 4 | 05-18-2015 07:41 AM |
New owner... a few questions | Pavmentsurfer | Axial Yeti XL | 15 | 04-11-2015 05:00 PM |
New Owner with Questions | photocycler | Axial SCX-10 | 3 | 09-30-2014 02:53 PM |
New AX-10 owner questions | Trimmy | Newbie General | 4 | 12-28-2007 06:33 PM |
New WK owner with questions | RC_Feen | HPI Wheely King | 5 | 04-21-2007 09:11 PM |
