06-10-2017, 01:09 PM | #501 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
| Re: Must watch video hd gear mod
[QUOTE=BarHarborBasher;5716939] I wouldn't think the heat will be such a big problem, I would rather think you will find a lot of brass debris inside! nevertheless, it make sense since that bushing is standing still against the rotating pinion. A thrust bearing would have done the job, but unfortunately there is none on the market on those dimension :( |
11-30-2017, 10:06 AM | #502 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
Bump 🧐
11-30-2017, 04:12 PM | #503 |
| Re: Must watch video hd gear mod |
12-22-2017, 03:26 AM | #504 |
Quarry Creeper Join Date: Feb 2016 Location: Australia
Hi all. I'm looking to get an Xl once I can sell my 4x4 slash. Is this the only mod that needs to be done to It? Or it's not necessary on 4s. I live in Australia so I'm worried about breaking parts as they cost a lot more here. Sent from my SM-G935F using Tapatalk |
12-22-2017, 03:36 AM | #505 |
Most important is to change ALL the bearings. After that is at your choice. This mod or three bearing mod (with perfect shimming), steering rack and drive shaft mod is what you HAVE to do. All the rest are optional. Also depensing if you are planning to run on 4 or 6S
05-28-2018, 12:08 AM | #506 |
Any updates to this? Also.. cant we just drill 1mm more off the screw holes in the diff to move the pinion away and remove 1 or 2 shims? If the 3 screws set the pinion mesh if the holes were further down wouldn't it work the same? |
06-04-2018, 11:44 AM | #507 | |
| Re: Must watch video hd gear mod Quote:
This is what I think about my diffs oho btw the rear tires were tapped rear diff 1,000000 cSt chttps://instagram.com/p/Bjf28AugxlG/ Last edited by BarHarborBasher; 06-04-2018 at 11:48 AM. | |
06-05-2018, 10:29 AM | #508 |
Rock Stacker Join Date: Feb 2017 Location: Finland
My personal (but very enlightened ) opinion. There is NO SUBSTITUTE for BHB pinion mod. That is the only way to get a perfect mesh with no slop with the hd gears. Nevertheless there is one single thing I think does more than BHB mod, and it is a Good Slipper!!!! e.g. Robinson Racing RRP1564 does the job. You can also use the mod1 50T spur from Robinson Racing RRP7350 if you want mod1 gears. (ok diameter to be able to match the orig. distance between shafts and gear ratio). A good slipper will save a lot. Or center diff, but you need BHB level of scratchbuilder in you to do that. |
Must watch video hd gear mod - Similar Threads | ||||
Scx10 Comanche Music Video FINAL EDIT! Watch in HD | ray2286 | Videos! | 11 | 03-13-2011 12:21 PM |
Most BADASSESSSSS video EVER, EVER!!! Watch it! | toyofast | Chit Chat | 19 | 08-04-2010 10:23 PM |
Wow watch this video. | dezfan | Chit Chat | 10 | 09-23-2007 09:35 PM |
Watch this 1/6th Video AMAZING! | DirkDigler | General Crawlers | 3 | 03-06-2006 07:01 PM |
