04-08-2016, 11:12 PM | #81 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
| Re: BHB custom Yeti XLX
I think I'm gonna us a hot wire...leaving excess then sand the nubs down then hitting them with the dremel buffer for a factory finish... IF all goes well...
04-09-2016, 12:04 AM | #82 |
| Re: BHB custom Yeti XLX Last edited by BarHarborBasher; 04-09-2016 at 12:07 AM. |
04-09-2016, 02:26 AM | #83 |
| Re: BHB custom Yeti XLX |
04-09-2016, 02:43 AM | #84 |
| Re: BHB custom Yeti XLX The more I look at them the more I like them!! I can notice a considerable amount more of traction turning them against the table!!! No Joke ! Rock crawling, mud fling, snow digging, water crossing MoFos !! Last edited by BarHarborBasher; 10-02-2016 at 03:55 PM. |
04-09-2016, 11:38 AM | #85 |
| Re: BHB custom Yeti XLX Yup and i put mine here So uh, where do I put the gun? :-) |
04-09-2016, 12:18 PM | #86 | |
| Re: BHB custom Yeti XLX Quote:
I can't wait to see how this thing preforms... | |
04-09-2016, 12:52 PM | #87 | |
If i was 75-100% crawling like your YXLX is more than likely to be doing i would NOT have it on there as even the softest bar is too stiff. | |
04-09-2016, 01:34 PM | #88 | |
The sway bars are ONLY for high speed runs and bashing.. That's why I came up with the caster block, duel control arms, and a set of these | |
04-09-2016, 01:37 PM | #89 |
I plan on flipping the A Arms back into stock position for high speed runs.. I plan on breaking 100 mph with my Crawler LOL
04-09-2016, 03:26 PM | #90 |
04-09-2016, 03:42 PM | #91 |
04-10-2016, 10:59 AM | #92 |
| Re: BHB custom Yeti XLX Another order coming in to make the XLX a DHAWK FULL DRESSER below items price: 1-Aluminum Steering Knuckle Carrier Set Gray For Axial Yeti XL AX31019 $31.5*1pc*0.8=$25.2 1-Aluminum Front Hubs Gray For Axial Yeti XL AX90032 AX90038 $39.99*1pc*0.8=$31.992 1-Aluminum Front Bulkhead Black For Axial Yeti XL AX90032 AX90038 $68.88*1pc*0.7=$48.216 2-Aluminum Steering Bellcrank & Plate Black For Axial Yeti XL 90032 $49.99*2pcs*0.7=$69.986 2-Steel Front CVD Drive Shaft /w +8mm Hex Hub For Axial Yeti XL AX90032 90038 $34.99*2pcs*0.8=$55.984 1-Aluminum Bevel Collar Red & 15mm Diff Shims For Axial Yeti XL 90032 Dhawk Racing $14.99*1pc*0.7=$10.493 1-shipping Payment $10.0 Jimmy is more than willing to make a combo deal... Like I've said before... He's a great business owner.. Willing to communicate and cut deals on combs !! |
04-11-2016, 10:28 AM | #93 |
Rock Crawler Join Date: Jul 2015 Location: McKinney, TX
I need to become friends with Jimmy. He stuff is awesome top notch. I only see his stuff on ebay and they don't have all the parts you listed above. Does he have a list what he can do? Since you're his buddy, convince him to make some RR10 parts. I would like to see some YXL tires similar to the 1:1 you posted above. Maybe widen the front arms and the rear axle a bit and then put some tires similar to Badlands on it. Only they would need to be a bit taller. Badlands are too short. As tall as the stock YXL tires, a bit narrower, and a bit harder rubber so they don't roll. Good stuff as always, BHB. You're making me miss my YXL. |
04-11-2016, 11:34 AM | #94 |
I hear ya !! I'm always a fan of the pizza cutters !!! On my RZR4 I used 28" X9.5 front and back ... never went back to the 12".... Honestly a huge improvement strangely enough... funny I just looked up at the picture and noticed he ^ did the same thing ... same front and back lol |
04-11-2016, 02:57 PM | #95 |
| Re: BHB custom Yeti XLX XLX BEAST MODE XLX STEALTH MODE Got my bonging agents for the triple threat !! Polishing, fairing, painting & Assembly soon!!! But now I'm gonna be waiting EVERYDAY for that little box from Jimmy I'm gonna do my breakdown video next week hopefully!! not that anyone gives a shit... Last edited by BarHarborBasher; 04-12-2016 at 01:18 AM. |
04-12-2016, 12:25 PM | #96 |
I'm working on a new upper A-control arm design to limit twisting ... Should have it completed tomorrow |
04-14-2016, 11:18 PM | #97 |
04-15-2016, 12:13 AM | #98 |
04-15-2016, 08:35 PM | #99 |
Quarry Creeper Join Date: May 2014 Location: United States
this is freaking insane my only concern is how the rear steering is clocked, like its digging into the ground instead of turning up have you thought about it? i have no idea how to fix it tho lol |
04-16-2016, 12:36 AM | #100 | |
And as for your concern that also is appreciated !! I've also visualized forces and actions during operations and my thought is this... How much will it effect crawling...? When I'm bashing or High speed runs the rear will be locked.. I have thought about programing the servo speed and sensitively for bashing .... What the Hell will happen to my TSM ??? the thing would probably be so confused it would turn into a pretzel LOL This build should be wrapped up in a couple of weeks.. Unless I can convenes Chris HemiStorm to finish paint the XLX and take out for a brutal bashN & brutal review... I've got Rich from RCN lined up for a XLX beatdown... | |
BHB custom Yeti XLX - Similar Threads | ||||
BHB HC Crawler video | BarHarborBasher | Axial Yeti XL | 4 | 03-17-2016 09:29 PM |
Yeti custom rear subframe Ti braces | Crazykev | Axial Yeti | 12 | 12-28-2015 09:28 PM |
What do I need to make my own custom yeti output? | Tgreer | Tools, and Procedures | 0 | 04-19-2015 08:22 AM |
