04-16-2016, 10:39 AM | #101 |
Quarry Creeper Join Date: May 2014 Location: United States
| Re: BHB custom Yeti XLX
crawling shouldnt be a big deal but yeah lock it out for high speed since you cant clock ifs like a solid axle
04-16-2016, 10:48 AM | #102 | |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
| Re: BHB custom Yeti XLX Quote:
O I can ... I looked into taking the progressive bend out of the skid plate or sanding a bevel into the Sub-clip or... making a aluminum wedge shim... But for now I'll stick with it till the TEST RUN... Then the fine tuning will commence I really like the fact that you noticed the issue and pointed it out like a buddy It's all about the delivery ! Some guys are a little ruff about "what should's" and "how too's" | |
04-16-2016, 12:09 PM | #103 |
| Re: BHB custom Yeti XLX xmaxx Length: 29.84 inches (758mm) Front Track: 22.26 inches (540mm) Rear Track: 20.66 inches (525mm) Ground Clearance: 4 inches (102mm) Weight: 19.1lbs (8.66kg) Height (ride): 13.79 inches (350mm) Wheelbase: 18.92 inches (480mm) Shock Length: 7.4 inches (187mm) Tires (pre-glued): 8.0x4.0 inches (203mm) Wheels: 4.3x5.7 inches (110x145mm) Speed Control: Velineon VXL-6s Motor (electric): Velineon 1600 Transmission: Single-Speed YETI XL Length25.75in (654mm) Width:16.3in (414mm) Height:11.10in (282mm) Wheelbase:18.5in (470mm) Ground Clearance:2.48in (63mm) Weight:12.75lbs (5.78kg) MotorBrushless 2200KV 4 Pole Electric Motor RadioAX-3 2.4GHz transmitter ServosTactic TSX45, 151 oz-in ESCVanguard AE-4 XL YETI XLX Length25.75in (654mm) Width:18.3in Height:14.10in (282mm) Wheelbase:18.5in (470mm) Ground Clearance:4 5/8 in Weight:15.75lbs MotorBrushless 2200KV 4 Pole Electric Motor & 1700KV T8 SENSORED Radio T.S.M BLUETOOTH 2.4GHz transmitter Servos HITEC 7950 489 oz-in ESC MAMBA MONSTER X 7 5/8" mudslingers 2 SPEED DHAWK Last edited by BarHarborBasher; 04-16-2016 at 12:12 PM. |
04-21-2016, 10:35 PM | #104 |
| Re: BHB custom Yeti XLX I gave up on the XLX |
04-22-2016, 12:05 AM | #105 |
Rock Stacker Join Date: Feb 2015 Location: Netherlands
What happened???
04-22-2016, 02:06 AM | #106 |
HAHA It's been quite around here...just getting sick of polishing my parts !!! Its looking killer tho !!! I cant wait !! I ordered some extra goodies ! Everything should be here by Tuesday ... Hopefully have it wrapped up in a couple of weeks .. I'm getting liquid mask for my first custom Rc paint job...
04-22-2016, 02:22 AM | #107 |
04-23-2016, 12:42 AM | #108 |
| Re: BHB custom Yeti XLX |
04-23-2016, 05:31 AM | #109 |
Phase 2 is almost done... Just gotta polish the two Dhawk Bulkheads... Phase 3 Polish up the tubs, add adhesives , reassemble BHB internal cage, drivetrain, wiring, some mods, custom paint job then I'm ready to ripppppp!!! I've updated a new video on my Youtube page if you want to see it more in depth.. I have two clear bodies and some perma mask.. Any suggestions Anyone ?? |
04-23-2016, 05:37 AM | #110 |
I've got my Dhawk order coming Tuesday so I can wrap it up.. I also went against my better judgment and got a HR HD transmission gear set... I let ya know if its any different than the stock transmission drag..
04-23-2016, 07:52 AM | #111 |
Pebble Pounder Join Date: Apr 2015 Location: New Jersey
Wow its looking real good so far, cant wait to see it finished. Are those some kyosho madforce parts i see there? Also got your gears back and i havent installed them yet, need to go with a front aluminum bulkhead first. Yea been real quiet here, just installed the mamba x esc and so far so good, finally have some good steering power.
04-23-2016, 08:52 AM | #112 |
Ya I was going to pull the trigger on a Fo-Xx Ve last night then saw a video next to the XMAXX... changed my mind... XMAXX Soild axle crawler or a XL bomber.. I really want a durable transmission.. I think the Chain drive will hold up to 6s... I plan on re~engineering it and making it way stronger with a possible DIG option..
04-23-2016, 09:13 AM | #113 |
Yea the F-oxx looks like fun and love the body. Sure next to the Xmaxx it doesn't look like much but I have a soft spot for the mad force platform. It was my first real monster truck and they've rehashed it like a hundred times. All in all its a fun truck but can't hang with the new crop of trucks, suspension is kinda bouncy and the steering linkage is a big mess. Doesnt articulate to well also as its a 2 link setup.
04-23-2016, 10:26 AM | #114 |
I was thinking about building a suspension system for it as well as steering mod and a power transplant..T8 1350k.v sensored 6s......I don't think the axles could handle it.. But I have a hard time stepping down from the XL... One of these days I'm gonna pick up a B5..
04-23-2016, 11:37 AM | #115 |
Sorry Dionisi I meant to start of with a THANK-YOU !! I was sidetracked after you mentioned mad force..
04-23-2016, 11:54 AM | #116 |
04-23-2016, 12:10 PM | #117 |
Newbie Join Date: Mar 2016 Location: Toms River, NJ
Wow.....Amazing work you do. Can't wait to see the finished product.
04-23-2016, 05:45 PM | #118 | |
Rock Stacker Join Date: May 2015 Location: CF
04-23-2016, 06:15 PM | #119 |
I hear you, it's a good truck, I've had three of them, one with heavily upgraded with new era parts extended chassis etc. They were an old company that went out of business but I liked them, very raw no anodizing. Anyway it is simple and light and I did miss it for a while when I sold them but honestly the wheelies are fun for a while but can get tiring for me. I've had like every truck or have driven at least most of them. Even my beloved savage flux it was gettin old with all that crazy power and couldn't put it down. Standing backflips all day could barely blip the throttle. I've had the yeti Xl since it first came out and even with all its reliability issues it's still impressing me every time I drive it.
04-23-2016, 06:49 PM | #120 | |
BHB custom Yeti XLX - Similar Threads | ||||
BHB HC Crawler video | BarHarborBasher | Axial Yeti XL | 4 | 03-17-2016 09:29 PM |
Yeti custom rear subframe Ti braces | Crazykev | Axial Yeti | 12 | 12-28-2015 09:28 PM |
What do I need to make my own custom yeti output? | Tgreer | Tools, and Procedures | 0 | 04-19-2015 08:22 AM |
