Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Bomber XL
Old 12-22-2016, 09:27 AM   #21
Default Re: Bomber XL
Looking sweet my man
Lavaheadache is offline   Reply With Quote
Old 12-28-2016, 03:50 PM   #22
This is the weight of the aluminum & skidpan used for the chassis support. ( Under 7 oz. )
I getting ready to film the build series as well as wrap up a couple other builds !
BarHarborBasher is offline   Reply With Quote
Old 01-13-2017, 08:08 PM   #23
So I've finished the Bomber XL and I'm completely blown away by its capabilities!! I've loaded the first build episode ... Editing is wrapping up!
I can't believe that I dragged my daughter's powerwheels off on 2s...
Old 01-14-2017, 10:15 PM   #24
So I took a trip to my LHS to pickup some paint for the Bomber XL and took a couple of shots... I'm using the same Bomber scheme but the colors are going to be a base coat Red with black and silver graphics... I'm modifying the window roll cage support and adding the Bomber number as well ...
I love this one....
Think scale....In my Rig pulling my SidebySide....Maybe a side project...Converting a bomber into a RZR ...
Old 01-15-2017, 10:53 AM   #25
This is so awesome. I'd love for Axial to come out with a bomber XL.
Do they make any crawler motors for this size?
TOMS97ZJ is offline   Reply With Quote
Old 01-15-2017, 12:45 PM   #26
Woo that thing is nuts!
Mudman is offline   Reply With Quote
Old 01-15-2017, 09:06 PM   #27
Oho ya the Tekin T8 Sensored is amazing and this week I'll be testing out Castle Creations New Sensored motor.
I actually the 2200 works great with a two speed and a 12 tooth pinion !
I'm actually going to Axialfest in July to show R&D my project so maybe you might see one on the shelves one of these days...
Old 01-16-2017, 06:52 PM   #28
Took the rigs out with my buddy today
.. The best part about building RC is using them !!!
Old 02-02-2017, 02:24 AM   #29
Bomber builders Series Episode One
https://youtu.be/TknOGRkzuhc
Bomber builders Series Episode Two
https://youtu.be/yQCVe8W_6ag
This video covers the custom How-to
center driveshaft , modification & rear axle extension (Plus 26mm),
Modified Losi HD outputs 4:02
Hub extension 7:48
Dog bone repair 11:17
Proper HD pinion shimming
and 3rd bearing mod 14:06
Differential shimming &
proper backlash 23:06
Old 02-04-2017, 09:53 PM   #30
Old 02-04-2017, 09:56 PM   #31
Quick Bomber XL run
https://www.instagram.com/p/BQEE4dhA...j9ZOXf6Iofhg0/
Old 02-04-2017, 10:04 PM   #32
That's so rad. What do you charge ball park for one like that?
Axial needs to make one. Just finished my xl and now I want a bomber. Would rather have an XL sized one.
Old 02-04-2017, 10:42 PM   #33
It would depend if you wanted to buy a kit plus the extra components OR to buy all aftermarket parts and chassis two chassis modify for a full custom bad boy.. my next move to to have my machinist to mill out 4sets of HD drivetrain components for a 12s 2028 capable rig..
Old 02-06-2017, 09:17 AM   #34
BHB Bomber XL Builders Series Episode 3
( https://www.youtube.com/watch?v=bB4qy6ogc-I&t=1166s )
This video covers...
Rear Pinion Shield/Deflector 1:10
HD Stock Drive Shaft Mod 4:20
Bonus : XLX Extreme Donuts 9:44
Mod installation of a Castle Cerations Quick Link 10:28
Bonus LVC 4s 10/68 8' icy vertical 13:05
Holmes Hobbies Servo By-Pass 13:40
Adding a extra battery plug 17:04
Converting a HDAR60 Yeti XL Axle 18:13
Bonus : 2200Kv 6S Airbullet 25:57
Old 02-10-2017, 11:08 AM   #35
It would be great to see Axial supply a internal cover like this...
I've also cut out 10lbs of lead for my scale plow and for pulling around XMAXX's too.. look forward to seeing the TUG OF WAR with the XMAXX VS XLX and the Bomber XL vs XMAXX and XLX vs Bomber XL ������
Old 02-11-2017, 02:58 PM   #36
I was testing out the snow guard and the bomber XL on 6s and it able to go up over Hills in 15 inches of Fluffy snow without dragging a pumpkin..
Yep that's a Monster energy drink can in the snow... I really was impressed with the rtr on 6S...But this Sensored combo with 100c Maxamps is insane !! Hydroplaneing is simply with this beast.. look forward to seeing the world's Fastest straight axle RC test runs soon !!
Old 02-12-2017, 02:50 PM   #37
The reason why it hydroplanes
6S tire balloon test they go from 8"1/4 inches to 15 in about a half a second at 3/4 throttle
https://www.instagram.com/p/BQbOoJcg...rLQO0feW5LOk0/
Old 02-16-2017, 07:32 PM   #38
Phase One complete with the aluminum conversion . Next step tig welding the c hub to the aluminum axle adapters and attachment to the Vanquish axle ..
I'm having a machinist make up a HD U-JOINT conversion. He's currently in the works making MOD ONE conversion that are extra wide. Next is MOD ONE transmission gears. My chromoly slipper shaft has held up awesome no wobbling anymore! Even with a locked up slipper... Yep that's the kind of power the Sensored 2200/MMX + Maxamps 100C + XT 150 will do .....
Old 02-20-2017, 11:04 AM   #39
Phase Two
1054 o.z steering servo . I'll have a unboxing video over this beast on my YouTube channel.
Hopefully it lives up to its hype!!
Should be good for a 16 lbs vehicle sense its intended for a 35+lb rig.
KEY FEATURES
Improved integrator design eliminates crowbar effect and reduces heat build-up
Socket-head cap screws
HV for use with 2-cell Li-Po’s
Waterproof
Steering and throttle options available
Removable, hi-strength servo lead
Low profile standard 1/5-scale size
Hardened steel gears
Dynamic breaking provides extreme precision
Zero-fade performance
Insane holding power
Proprietary & patent pending software provides unmatched performance & precision
Extreme performance level eliminates need for dual servo setups
PRODUCT SPECIFICATIONS
Size Category:SpecialtyTypeigitalApplication:1/5 Scale SurfaceTorque:1050 oz-in (75.6kg-cm) @ 8.4V, 910 oz-in (65.5kg-cm) @ 7.4V, 736 oz-in (53kg-cm ) @ 6.0VSpeed:0.20/60deg @ 8.4V; 0.23/60deg @ 7.4V; 0.28/60deg @ 6.0V, at no loadLength:2.5 in (63.3mm)Width:1.20 in (30mm)Height:1.87 in (47.50mm)Weight:5.0 oz (142g)Bushing Or Bearing:BearingBearingualConnector Type:Z-ConnectorGear Type:MetalGear Material:SteelCurrent Draw Idle:16.8mA @ 6.0V; 17.2mA @ 8.4VCurrent Draw Stall:4.9A @ 6.0V; 7A @ 8.4VVoltage:6.0-8.4VDeadband:4µs
Dynamic breaking technology assures the vehicle maintains the heading demanded thanks to the servos brute level of holding power. An improved integrator design virtually eliminates the crowbar effect while keeping the servo temps low through even the most grueling of runs. Using Back EMF technology, position lock exponentially improves the servos ability to keep its position while greatly increasing holding power. In addition, the S9020 offers virtually zero servo fade, no matter how much is thrown at them. Forget about doubling up on expensive and heavy dual servo mounts. The S9020 won’t fade under any condition.
Old 02-22-2017, 11:48 AM   #40
I did some research and found some alloy dowel pins that should be a suitable upgrade! The only issue I've had with the Bomber XL is breaking the hex pins & output/sun gear pins.
After fitting them I'll look at the oversized category for a refined fitment.
This will cover the transmission pins as well. Let me know if you guys want a kit after I hash out the best fit.
And yes that's a pinion bushings! The other ones that I ordered were miss labeled.
Bomber XL - Similar Threads
Making Crawling bomber into trail rig bomber. theTman Axial RR10 Bomber 2 06-10-2016 01:46 PM
