02-22-2017, 02:08 PM | #41 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
| Re: Bomber XL Last edited by BarHarborBasher; 02-22-2017 at 02:11 PM. |
02-22-2017, 02:18 PM | #42 |
| Re: Bomber XL |
02-22-2017, 02:19 PM | #43 |
| Re: Bomber XL
I did some research and found some alloy dowel pins that should be a suitable upgrade! The only issue I've had with the Bomber XL is breaking the hex pins & output/sun gear pins. After fitting them I'll look at the oversized category for a refined fitment. This will cover the transmission pins as well. Let me know if you guys want a kit after I hash out the best fit. I chose standard sizing because it comes in oversized options for closer fitment than the metric bore in the drivetrain components. Also a military spec grade pins are available which are made of the best materials. And yes that's a pinion bushings! The other ones that I ordered were miss labeled. Last edited by BarHarborBasher; 02-25-2017 at 12:45 AM. |
02-25-2017, 01:03 PM | #44 |
| Re: Bomber XL |
02-25-2017, 02:59 PM | #45 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Bomber XL
Is the rim a real beadlock? Link to more info?
02-25-2017, 03:10 PM | #46 |
| Re: Bomber XL |
02-28-2017, 07:11 PM | #47 |
| Re: Bomber XL
I got the 1,000 O.Z servo all mounted up and revised my servo battery situation. So I decided to install a b.e.c /servo battery and a b.e.c /light battery in the weight box . It should help keep the front end down and the electronic components dry with a factory look. So I decided to install a power port on the outside of the box so I didn't have to open it up for charging and disconnecting servo/lights power supply. Last edited by BarHarborBasher; 03-01-2017 at 03:43 AM. |
03-01-2017, 03:39 AM | #48 |
| Re: Bomber XL
I've got the BHB Pinion bushing installed and I'm really pleased with how well the Yeti XL center driveshaft work as axle shafts. To work on the axle is a snap. Remove the hub carrier and pull out the driveshaft or pop out the differential carrier.. Can't wait for testing ! On the bench the bushing didn't show any signs of heat with my heat gun...Fingers crossed If all goes well I'll be giving out some BHB Pinion bushings. |
03-02-2017, 02:35 PM | #49 |
| Re: Bomber XL |
03-12-2017, 10:54 AM | #50 |
| Re: Bomber XL |
04-24-2017, 10:34 AM | #51 |
| Re: Bomber XL |
04-24-2017, 11:23 AM | #52 |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
| Re: Bomber XL
Top notch,A-1, Kudos, outstanding! Truly an inspiration! |
04-24-2017, 12:04 PM | #53 |
| Re: Bomber XL |
04-24-2017, 04:27 PM | #54 |
Pebble Pounder Join Date: Feb 2017 Location: Droning
| Re: Bomber XL
I started out with the Yeti Xl because of his videos. Your definitely following in his footsteps!
04-24-2017, 05:02 PM | #55 |
Rock Stacker Join Date: Jun 2016 Location: Southern California
| Re: Bomber XL
Nice cut Bro
04-25-2017, 01:50 AM | #56 |
Newbie Join Date: Apr 2016 Location: Anchorage
| Re: Bomber XL Quote: Lot of words and shit, does this fit the stock yeti xl enclosure? Look bad ass man. Sent from my iPhone using Tapatalk |
04-25-2017, 07:06 AM | #57 |
| Re: Bomber XL
Not at 2.5 inches long... It's gonna need to be modded to fit. Shouldn't be a problem for a car builder.
04-25-2017, 07:07 AM | #58 |
| Re: Bomber XL
No, its a 5th scale servo.
05-18-2017, 12:55 AM | #59 |
| Re: Bomber XL |
06-07-2017, 12:25 PM | #60 |
| Re: Bomber XL |
Bomber XL - Similar Threads | ||||
Making Crawling bomber into trail rig bomber. | theTman | Axial RR10 Bomber | 2 | 06-10-2016 01:46 PM |
