Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Help..........! Stripping wheels like crazy!
Old 04-03-2017, 08:20 PM   #1
Default Help..........! Stripping wheels like crazy!
Help!
I have now stripped two wheels on the same side, same axle. I have tried, double wheel nuts, locktie, I do torque the wheel nuts. Not sure if I should change the hub.
Any suggestions would be greatly appreciated.
Thanks!
RCWERKZ is offline   Reply With Quote
Old 04-03-2017, 11:34 PM   #2
Default Re: Help..........! Stripping wheels like crazy!
I like the Hot racing hubs and Serrated nuts. They also add width which I have noticed has reduced tipping. The nuts are wider and give better clamping plus they have the reinforced wheel rings which help support the wheel hub. I would also buy a good 17mm wrench. Before this I used similar wheel nuts that stopped loosening. The wheels that are stripped, just unglue them in the oven.
MaxxPain is offline   Reply With Quote
Old 04-04-2017, 06:32 AM   #3
Teflon tape.............works great!
Dairy guy is offline   Reply With Quote
Old 04-04-2017, 10:50 AM   #4
Can you post a close-up pic of the troublesome hub(s)?
Pete9 is offline   Reply With Quote
Old 04-04-2017, 03:00 PM   #5
Originally Posted by RCWERKZ View Post
Help!
Thanks!
I mentioned on your Instagram that I cut the small lugs which helped me save almost 6 ounces and I added extra slits that line up with the webbing of your 40 series Wheels. If you take to the caps and put them slit side to Slit side and offset them it will Mark out where the additional slits need to be.
This is why I came up with my 40 series RC 4 wheel drive hub adapter mod
https://youtu.be/P5bILs2Yg9E and I cover it on a previous thread stripped wheel mod
If you are throwing away the stripped wheels I buy them
BarHarborBasher is offline   Reply With Quote
Old 04-10-2017, 01:48 PM   #6
I have these and I am only on 4s but I have not had any issues.
The red annodizaton does wear off easier than I expected. :(
Adidas4275 is offline   Reply With Quote
Help..........! Stripping wheels like crazy! - Similar Threads
need help stripping paint from wheels. puffntough760 Paint and Body 0 06-18-2014 02:37 PM
my wheels are stripping out toyodaaddict Axial SCX-10 10 02-28-2013 06:22 PM
Stripping the chrome off pede wheels neo Tires and Wheels 11 05-08-2006 08:39 AM
stripping anodizing off of wheels wally187 Tires and Wheels 4 01-17-2005 07:06 PM
HPI savage wheels stripping out???? cman_1500w Tires and Wheels 5 09-10-2004 06:05 PM
