04-19-2017, 05:09 PM | #1 |
Pebble Pounder Join Date: Apr 2017 Location: Fresno
| Pinion bearing Clip???
My bearing failed on the rear differential in front of the pinion gear But a portion to see clip is still attached is there a specific tool used to open up see clips I'm having a hard time with pliers and screwdrivers I have new gears new axle housing new fast Eddie bearings coming and would like to prep it all to be ready |
04-19-2017, 07:28 PM | #2 |
Pebble Pounder Join Date: Feb 2017 Location: Droning
| Re: Pinion bearing Clip???
Ive always pushed it out with needle nose pliers, pushing on each end simultaneously. That either pops it out altogether or gives me a little gap in the middle where I can stick a flat blade to pop it out the rest of the way.
04-19-2017, 08:08 PM | #3 |
| Re: Pinion bearing Clip??? |
04-20-2017, 09:11 AM | #4 |
Quarry Creeper Join Date: Apr 2016 Location: Cape cod
I just use my thumbnails and push, then again I have a working mans grip so that probably makes a difference.
04-20-2017, 09:36 AM | #5 |
I think that means you have super strong thumbnails. |
04-20-2017, 11:01 AM | #6 | |
| Re: Pinion bearing Clip??? Quote:
So perhaps it seized to the bearing when the bearing failed. It doesn't even spin. I bought all new hardware for it and if I can get the clip off I'll salvage components. I got a good deal on drive shafts, bearing, shims, pinion all assembled already and new. Thanks for the info | |
04-20-2017, 12:52 PM | #7 |
If it doesn't spin, how about a flat blade screwdriver and some hammer taps to it.
04-22-2017, 06:25 PM | #8 |
I will post a pic of it later. I bought all new drive line parts (OEM) and built a new one. That clip wont budge. :/ |
Pinion bearing Clip??? - Similar Threads | ||||
Pinion Bearing Issues | pro mod steve | Axial Yeti XL | 118 | 05-15-2018 12:35 AM |
Pinion carrier bearing issues | arnesto | RC4WD Trail Finder 2 | 21 | 02-14-2017 08:58 AM |
Removing the pinion gear E-Clip | Natedog | Axial AX-10 Scorpion | 10 | 12-22-2007 12:59 PM |
Pinion Bearing Walk? | sickfab | HPI Wheely King | 12 | 08-29-2007 01:28 PM |
